Question about Cameras
After cleaning the lenses the problem of not stright lines is occuring
  • kakima Dec 10, 2016
    Hi Arif Sk, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model camera?
Cmmunication between lens and camera is faulty.
Canon can have tight tolerances for their lenses and camera bodies. Some aftermarket lenses don't mate well. If the problem occurs with other lenses as well, try cleaning the contacts on the lens and camera with a clean, soft cloth or rub them VERY LIGHTLY with a new, clean pencil eraser, taking care no particles drop into the camera or lens. If this doesn't correct the issue you probably have a damaged contact or lose contact in the camera or lens.
Jun 10, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
When press the brakes, the pedal go stright to the
check for obvious leaks from master cylinder unbolt it from booster leaving the lines connected and see if it's leaking follow your lines from there to each wheel and see if you see a bad line and if it has drum brakes on the rear pull the drums off and see if the wheel cylinders are leaking if they are leaking and the brake shoes are soaked replace the shoes too.
Nov 11, 2009 | 1999 Chevrolet Tahoe
Will not play games... doesn't spin disks
Your lense element has probably gone. You'll either have to replace it yourself or get Sony to repair it for you.
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Drawing problem in PS cs4
Go to your Brushes.
Click on the Brush Tip Shape tab.
Make sure the box is ticked that says 'Spacing' and set it as low as you can (1%) for the smoothest effect.
Aug 16, 2009 | Computers & Internet
HP 5610xi all in one printer, Lines in the copy
Are these dark lines or 'white' lines where ink isn't being applied to the paper where it should? And are they horizontal or vertical lines on the page?
If vertical lines on the page, follow these instructions:
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
the flashing ? mark means its not seeing any bootable device do you have the original OS disk from apple???? If you do you need to boot with them and test the hard drive to see if its functioning and or there is an OS issue.
Oct 31, 2008 | Apple iBook Blueberry Mac Notebook
Lines on scanned images
if the lense has dust on it how do i clean
Oct 29, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
BLACK STRIGHT LINE CAME VERTICALLY WHAT I WANT TO DO your question is not clear. but it suonds me that 1 it is due to deflection connector is loose 2 problem in h/ output section related to hor. deflection coil assembly. good luck.
Sep 26, 2007 | LG Flatron L1750S 17" LCD Monitor
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
