Question about Building Materials
When the temperature gets near or below zero, my door comes part way down and then reverses. It works perfectly at higher temps. do you have a solution?
  • 16,584 Answers
I re-categoried this question, hope it was garage door related. There is an adjustment on the motor unit that sets the reverse threshold if the door hits something. When it gets cold, lubricants can get thicker and the door senses the resistance and opens when trying to close. You can change lubricants or set the adjustment to a higher setting
Posted on Dec 10, 2016
Sub zero 700br shuts down
If this machine takes to much time to get to temp. Or doesn't shut off once it reaches the right temp then the board will sense a problem and shuts it down. It could definitely be a thermistor causing the problem. I work on tons of these machines. Onetime I fixed a customers machine that had a leak in the sealed system. I fixed and charged it with freon it was working perfect when I was there. The next day customer called the machine was off I went there couldn't find any problems. Restarted it same thing next morning it was off. Long story short the man had it so filled that it was taking to long to get to the right temp it was shutting down. So the next time it shut off I showed the customer how to restart it before it lost temp. Never had anymore problems.
May 11, 2014 | Sub-Zero 632 / S
Defrost cycles
Defrost cycle usually comes on after about 7 hours. If it is happening every 30 minutes or so, the defrost timer is not working properly and your internal temperature will never have a chance to go down to zero as SOP.
When defrost cycle comes on, the compressor is automatically shut off and internal freezer temps can go up by close to 25 degrees or more. It is for this reason that commercial freezers do not have auto defrost - the latter extols a price, convenience at the price of higher average temps and less time to properly store foodstuffs in freezer.
Nov 20, 2013 | Freezers
Gladiator Model No. XXRK- Freezer door was left ajar overnight a little while ago - Now I cannot get the temperature back to zero. I cleaned a blanket of dust off condensor coil- no change... Not Always-...
Gladiators are a unique breed from any other style of refrigerator for their convertible capabilities of altering which section you wish to be the fresh food or the freezer, and the ability to use it in colder ambient temperatures than a typical residential refrigerator. This unique capability requires the use of a reversible fan motor and and dampers as well as additional foam insulation. If the door was left open, you have likely a buildup of frost and or ice in these air ducts as a result. My advice, empty it out, unplug it, open BOTH doors, blow a fan into the cabinet for a minimum of 24 hours. The water coming from the suction line of the compressor could be a sign that there is a little too much refrigerant in the system, or that it is in a fairly warm area, or near some source of heat.
Oct 03, 2010 | Gladiator Freezer GAFZ21XXRK
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
The freezer stops working when the room temp drops below 60
Refrigerator operation is controlled by the internal temperature . When there is very little ambient heat available to leak in to cause it to cycle more frequently and there is no door traffic to be a heat source the freezer temperature will increase. Keep the room heated to a higher temperature or remove frozen products is the answer. A small chest type freezer will keep food frozen while you are away and have the heat turned down.
Nov 11, 2008 | Refrigerators
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
Greetings bkbkbt,
Many times this behavior is an early indicator that your unit either needs freon or might have a compressor issue. I would advise contacting a repair person before this problem gets worse.
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
Building Materials Logo
66 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
