Question about Waterwise Water Dispensing & Filtration
We have a 7000 three gallon model and this morning we noted it was running constantly but it's not heating up. Apparently it's just a fan running.
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: My LG 7000 BTU Heat / Cool Window Air Conditioner
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
Posted on May 24, 2010
Cooling fans running constantly is this normal susuki vitara 2007 2ltr petrol
No... constantly is not normal...!!
Hello John Burns,
The vehicle (by design) is targeted to operate at
180 degrees Fahrenheit ... Look for a thermostatic switch on or near the top of the radiator. For these purposes I STRONGLY RECOMMEND workshop or FACTORY repair manuals.
I have noted that most makes will keep the fan running AFTER the ignition is off... but that could easily be verified by looking at (make & model needed here) your UNDISCLOSED
vehicle's WIRING DIAGRAM ...
Present complete issue statement:
"Cooling fans running constantly is this normal"
Popular USA market vehicles TOTALLY FREE
wiring & TECHNICAL SERVICE BULLETINS
are available on BBB Industries website (below)
Hope this helps...
I see issue now show Suzuki 2007...
I do know engines BEGIN to run correctly ABOVE
180 degrees Fahrenheit..
Buy a NEW THEMOSTATIC FAN SWITCH
Apr 14, 2017 | Cars & Trucks
I am new to a heat pump. The thermostat has an 'auto' setting and an 'on' setting. I am confused as to which one to use for heat. Can you help me?
n most heat pump thermostats you have two control switches and the temp setting. One control switch will say "Heat", "Off", "Cool" while the other says "On" and "Auto". The three position switch is for whether you are heating or cooling. The two position switch is for the fan control. "On" will make the fan run constantly whenever the three position switch is in HEAT or COOL mode. Some people use this to circulate air at all times. MOST people use the AUTO mode, where the fan is controlled by the circuitry and runs during the times of heating and cooling only.
Oct 16, 2015 | Heating & Cooling
Kenmore humidifier model 15420 wont turn on.
If its like mine, one or both of the fans short out causing the fuse to blow in the controller. I was running with a replaced fuse and 1 fan while waiting for a replacement fan. The remaining fan also blows the fuse now. I think maybe there is a fan issue?
Feb 23, 2014 | Kenmore 14 Gallon Humidifier Model 15420
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
I have to run my unit in safe mode or else the cooling fan constantly runs and then shuts itself down. Its only 2 or three yrs. old. Junk or fixable.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 21, 2011 | HP Computers & Internet
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
May 24, 2010 | LG Heat cool Window Air Conditioner
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Fan slows to about half speed when heat cycle kicks in
The heat fan speed is slower than the cooling speed. About 300 rpm less.
You may not have a problem.
May 20, 2009 | LG Heating & Cooling
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
Water Dispensing & Filtration Logo
1,212 people viewed this question
Top Waterwise Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Waterwise Water Dispensing and Filtration Expert? Answer questions, earn points and help others
