Question about Toro Garden
Where is the spark plug located on Toro 725E snow blower
  • Toro Master
  • 1,871 Answers
2 Suggested Answers
  • 6468 Answers
SOURCE: Where is the spark plug located on a Toro LX425 Lawn mower ?
look for a large black wire on the front of the engine and the end that has a rubber boot on the end pull that off the plug is under there
Posted on Apr 08, 2012
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
Is a Champion RJ19LM equivalent to a R C J 8Y?
Feb 25, 2015 | Toro Power Clear 221QE Electric Start 21...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Snow blower wont start
clean the fuel out and the carb , make sure you are getting spark close the choke to start then shut if off or it will foul the plug
Feb 17, 2014 | Toro Snow Blowers. Power Clear 18 in....
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
pull the back cover off it is there follow the big fat wire which is your coil takes you to the plug , 13/16
Jan 25, 2014 | Toro Snow Blowers. Power Clear 621 QZE 21...
No spark on toro ccr 2000 single stage snow blower
The kill switch cable on the handle my be broke
Oct 24, 2012 | Toro Power Lawn Mower
I have a toro snow blower that makes a popping sound when pulled but wont start any ideas
Have you tried using starter fluid? Sounds like the timing may be off or it may be flooded. Pull out the spark plug and see if it is wet. If so dry off the plug and pull the engine over with no plug (move the spark plug wire away from the spark plug and ground it out so it wont cause a fire). This will spit out the excess gas in the cylinder and then put it back together and try again. What model is the Toro?
Nov 12, 2011 | Toro Lawn Mower With Toro Power Tools
Snow blower spark plug replacement
I would check it at the start of every season and clean it. If you note that it seems to be running rich and might have fouled the plug, you can always pull it and check it again. Probably not a bad idea to check it before you put it away for the season. As for replacement, it depends on condition. I would think that you should get two or three season's use out of it before needing to replace it, at least.
Jan 25, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
