Question about Dayton Gas Furnace Heater
Need to find a temp. reg. relay
I've got a Ultra 97 furnace & the relay/transformer is bad. I beleave this was manufactured by Magic Chef. The relay is an Essex part #632-310580-2111 36634C001. The relay has 4 wires comming out. (2 black & 2 red) Any idea where to locate this or a replacement. Most I found only have 3 wires comming out.
Thanks
Kenny
3 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: Can't get new thermostat to work
When you have only 2 wires it is set up to run just a heater only. If this is a central heat/air unit, you would have 4, red for Hot, White for heat, green for fan, and yellow for cooling. sometimes they will have a blue wire that's not being used for a spare only.Some times you can use just the heat part of the stat if you connect the Red to r and if the subbas'e says Rc and Rh .If so, try connecting red to red and if it does say Rc and Rh that means red cooling and red heating.Run a jumper wire across the 2 reds along with the red from the wall. Connect white to w.Try programming the heat and see if it fires up. If not, you will have to replace stat with a 2 wire Heating only thermostat. Do not pull any wires up from the transformer as you will burn it out!! Just remember, 2 wires are for a heater only!4 are for heat and cool, and 8 are used for a heat pump.Sometimes the new stats have the red jumper wire in place and all you have to do is hook your red to either end of the jumper, and then white to W. If no RCand RH, get a heat only stat, or it will never work believe me, I know this.Good Luck and let me know if you need more help. Shastalaker7
Posted on Nov 07, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: installed dayton nat gas hanging furnace in garage
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Posted on Dec 11, 2009
I need to find replacement parts for a Magic Chef propane furnace model EG6E80. How can I cross reference them with other brands?
good luck, what parts do u need, most of them can be re placed with other furnace name brands, like ignitor, blower motor, gas valve, pressure switch, ignitor board, transformer, ventor motor, they have replacement for all those parts, remember most companies use the same parts
Dec 16, 2015 | Heating & Cooling
Magic chef furnace G66-100D-5
Go to magic chef.com get the manual
Nov 01, 2014 | Heating & Cooling
Need to rewire a furnace with a transformer
http://www.electrical-online.com/thermostat-wiring-explained/
Nov 26, 2013 | Magic Chef Dryers
How do i wire the thermostat to the magic chef furnace
Inside the furnace there is either a transformer relay with the markings of R & W stamped near the terminals or T TH or a circuit board with terminals marked R and W. This is where your thermostat wires will connect to. At the thermostat, connect the R terminal to the wire connected to the R terminal at the furnace or T terminal at furnace. The other wire goes to the W terminal on the thermostat. This will give you heat
Jan 16, 2011 | Heating & Cooling
I have a magic chef ultra 97 furnace. the blower started making a noise. i removed the blower and blowed the blower out with air and lubed the back bearing with pb blaster. reinstalled blower. the blower...
u may have a bad ignitor or u might not have hooked up a safety switch or u may have accidentally caused a sensor to go out not knowing but it sounds like the ignitor is bad is it a glow plug or does it spark to light
Feb 26, 2010 | Heating & Cooling
I have 210k btu Magic Chef gas fired furnace and I need a model #
Replace the start capacitor. Take an amp draw on the motor when it starts. Compare that with the rating plate for FLA.
Nov 04, 2009 | Continental Heating & Cooling
I have an old Magic chef furnace and need to replace the Fan Motor were can I find the fan spec for replacement? It was built in 1987 Model # G8A75DC10-17 Serial# A 10221CKA Forced Air Furnace Categorie I
magic chef furnaces were discontinued many years ago. Pull the motor and take it to your local motor shop. They will be able to match it. Furnace blower motors are pretty standard fractional horse motors.
Oct 06, 2009 | Heating & Cooling
Gas Furnace burner shuts off after a minute even with new sensor
BE AWARE THAT MAGIC CHEF IS NO LONGER IN BUSINESS!
In my experience a 20 year old Magic Chef probably has a bad heat exchanger which can cause carbon monoxide poisoning and can not be replaced since Magic Chef is not around any more!
Today’s furnaces are controlled by a computer which constantly monitors for problems. When it detects a problem it will shut off the burners. Depending on the problem and the specific furnace it will either “lock out” the furnace or cycle it through a purge (to rid it of un-burned gas and excess heat) and then attempt to re-start it. If the problem continues to occur then it will “lock out”. Depending on the problem and the furnace it may again attempt a re-start after several hours. In any case if the problem was not detected/caused by a sensor which requires a manual re-set, when the power to the computer is interrupted or the call for heat is interrupted the computer is reset and it will again attempt to re-start the furnace. The most common problems are:
· Low or lack of flame sense. Different furnaces use different methods to detect a flame – often these “flame sensors” become dirty and have to be cleaned (usually with sandpaper or steel wool).
· Bad igniter. (Doesn’t light at all).
· Clogged combustion air intake or exhaust.
· Clogged condensate drain. (90+% efficient furnaces).
This is not a complete list, only the most common!
Depending on where you live your HVAC system runs more than anything else you own (including your car). All furnace manufacturers “recommend” “regular maintenance” of your furnace. In fact, all that I am aware of state in their warranty that the warranty may be voided due to lack of “regular maintenance.” The industry has defined “regular maintenance” as yearly (in fact, some manufacturer’s warranties state yearly). Due to safety, liability, and the need for many other things to be checked, cleaned, and/or adjusted (2-page checklist where I work) to ensure safety and efficiency. Due to the large number of furnaces and the differences between them. Moreover, due to the terms of this site, I WILL NOT AND CAN NOT give you specific instructions on how to perform repairs on your furnace. I suggest that you contact a local, reputable, HVAC service company for (a tune up, preventive maintenance, general maintenance, yearly service call, general service, or whatever they call it).
While I may not have told you how to fix your furnace yourself, I have told you how to fix it. Please rate my answer.
Mar 03, 2009 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
507 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
