My heater won't stay lit for an extended period of time. Thermocouple perhaps?
  • 28 Answers
This sounds like the thermocouple. I would clean the stub end where the pilot flame hits with steel wool. If this does not cure the problem, you may need to replace it. This item can be found at most hardware stores such as Lowes. Be sure to buy the correct length.
Posted on Dec 10, 2016
  • 3 Answers
SOURCE: charm glow gas heater won't stay lit changed
Dust build up inside the pilot light burner assembly. A clean pilot makes noise and has a blue flame when it is burning. A dirty pilot has a quiet and smaller flame with an orange tip.
Posted on Dec 06, 2009
  • 1214 Answers
SOURCE: Is it o k to bend the thermocouple tip. The only
Bending it will ruin it. You need to find out why the pilot flame is not as strong as it should be.
It is usually caused by bugs or spiders having gotten into the small air mix jet of the pilot assembly and died or built a web or, there is some dirt from the fuel that is partially clogging the fuel tube leading up to the pilot assembly, or plugging the orifice.
Posted on Dec 14, 2009
Testimonial: "worked perfectly"
  • 146 Answers
SOURCE: My Master propane heater will not stay lit. It
Yes this is probably the thermocouple connection.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
Posted on Oct 10, 2010
  • 120 Answers
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Posted on Jan 29, 2011
  • 125 Answers
SOURCE: water heater pilot light will not stay lit.
Hold the pilot button down for a full minute after it lights, then release. If this does not work then the thermocouple is not adjusted where the flame is heating it or you just have a faulty new thermocouple.
Posted on Sep 06, 2011
Won't stay lit just replaced thermocouple still won't stay lit unless hold button in
perhaps your pilot need adjusted so it is hitting the thermocouple better
Jan 12, 2016 | Heating & Cooling
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Tabletop heater won't stay lit
The first thing to go on a patio heater is the thermocouple, these are consumable items that need to be replaced depending on useage. Found this site very useful patio heaters problem solving.
Mar 25, 2012 | Heating & Cooling
Water heater pilot light will not stay lit. changed the thermocouple, and still won't stay lit.
Sep 06, 2011 | Heating & Cooling
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Wont stay lit
there is a thermocouple on this heater just like on a water heater. I have this heater and have to do this periodically. You will have to take a few screws loose but it is an easy repair. There is a tube that delivers the gas to this thermocouple and inside there is an orfice that meters the gas. Take a safety pin and clean out the end and it should stay lit for you
Nov 26, 2009 | Mr. Heater MH9B Ceramic Utility
Pilot light will not stay lit
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
