Question about Pool & Spa
How to re set timer on Hurlcon Spa filter - Pool & Spa
2 Suggested Answers
MOTORWIZJ
  • 1383 Answers
SOURCE: how do i drain the spa i have a sx series hurlcon pump. help!!
you need to be able to divert the suction from you spa pump to the lowest inlet in the bottom of your spa.you might need to install a valve.. jay the pool pump motor repair guy longwood florida
Posted on Jan 28, 2012
How to change sandin hurlcon sand filter
remove top shop vac out sand add new don't get any down pipe
Oct 10, 2017 | Pool & Spa
My hurlcon CX 240 pool pump has good return pressure but very low suction from the pool and wont opperate the kreepy krawly, Do I need a new pump? Thanks. Richard
no
what you may have is a blocked outlet--filter --tap incorrectly set
good pressure but no suction indicates that the pump is pumping but the pumped water has nowhere to go
Jan 05, 2017 | Pool & Spa
I have a HURLCON RX280 Sand Filter, if I replace the sand how much new sand do I add & to reinstall do I then fill up with water?
fill to the correct level as in the user manual
no need to fill with water as that will happen when you turn on the pump
Sep 29, 2016 | Pool & Spa
Hurlcon sand pump seems to pump water out of the pool. It's like it's on backflush all the time. Anyone had similar problems?
Either your Filters Valve setting is in the wrong position, or your filters valve needs to be rebuilt or replaced. (valve diverter or and/or valve gasket)
Jan 24, 2016 | Pool & Spa
Hurlcon ctx 2hp pump troubleshoot
maqke sure the intake union is tight also check to see if seal slipped use filter lube
Jul 02, 2014 | Pool & Spa
We have a hurlcon GX 600 cartridge filter that has suddenly stopped working and there is no flow...
have you cleaned filters lately? if not take out and clean filters soak in bucket with 4 parts water to 1 part muriatic acid if you have take filters out of canister put back together without filters try them to see if you have flow if not sounds like pump plugged something might be caught in impeller
Jan 26, 2014 | Pool & Spa
How to set Timer
need to set timer on hurlcon
Jan 14, 2014 | Hardware & Accessories
motor overheating replace pump
May 21, 2017 | Pool & Spa
Pool & Spa Logo
53 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
