My food processor won't start
It's a cuisinart DCL 8E
  • 5 Answers
SOURCE: cuisinart food processor
I went through the same it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Posted on Feb 06, 2008
  • 8596 Answers
SOURCE: cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Posted on Jan 15, 2009
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
  • 122 Answers
SOURCE: Need instruction manual for Cuisinart DLC-7 food
pl. see
Posted on Apr 16, 2009
SOURCE: need manual for food processor
Found it at:
Posted on Sep 15, 2009
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
Oct 29, 2011 | Cuisinart DFP-14BC Custom Food Processor
I have a Cuisinart DLC-8S TX Pro Custom 11 Cups Food Processor that I purchased in spring 2004 and used only sporadically. Last week, I burnt the motor by using it to make fondant. Big mistake. I take...
If you already have a lot of attachments for this model, I would purchase a used motor unit. I got a complete setup at a yard sale minus the work bowl cover for $3 as a spare, and often see them at thrift stores priced quite inexpensively. You could also check ebay. Motor units routinely go for less than $25 including shipping. I'm pretty sure most dcl-8 series motors will work with you bowl and attachments. I like the quality of the older units better than the newer ones. And if you watch ebay closely, you can pick up a lot of pieces really cheaply. Good Luck,
Oct 21, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
I need an operators manual for model DLC-8E food processor
This can be ordered from the Cuisinart web site:
Nov 27, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
WE need the pusher/sleeve assembly. The motor is
I don't recognize model #PLE-8E, but if you have a DLC-8E, while you can't get the original parts from Cuisinart, you can get a whole bowl/pusher/lid that will operate your old base. I also see a few auctions for the original DLC-8 series parts, but there is some asterisk by each of them - they will work, but they have a chip somewhere, etc. But, I would keep your eye on eBay - I picked up many a good Cuisinart item at a bargain price.
Feb 28, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC- 8M
Those older Cuisinart food processors have motors that generally last forever. But a replacement bowl can cost $118.00 or more. The newer processors like the DLC-8S do have a 3-year general warranty and a 5-year motor warranty. The new DLC-2011, 2007, 2014 series etc. have 10-year motor warranties. I like the collect the oldies, but the new ones have few problems even though they are made in China. If an old processor's plastic breaks, you have to buy a completely new bowl set - if a new processor's plastic breaks, then you can buy a single component piece to solve the problem. Hope this helps.
-Tha Mp3 Doctor
Sep 19, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processor assembly
Hi Janne,
I bought a DCL 8M about 20 years ago and still have the original manual. Mashing potatoes is one of the few tasks that the manual discouraged. The potatoes turn into glue. I tried mashing potatoes with the flat blade and extra liquid. It still tasted awful. I do puree potato soup in batches, First I mash all the solids (potatoes and leek or potato and tomatoes), then add the liquid. For some reason, pureeing the soup works well.
I am sorry I could not be more helpful.
Oct 08, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
