Question about Bulldog Remote Starter & T-Harness Kit for 99-03 Oldsmobile Alero; 97-99 Ol
Alarm is intermitent on 98 Olds aurora
When the car is shut off and the key is out of the ignition. The lights will flicker. You will also here a clicking noise from inside the car. I traced the noise to a black box that has two harnesses coming out from it. The black box is located near the hood release handle behind the dash panel. When I remove the larger harness from the box the lights stop flickering and the clicking noise stops. The only problem I loose power to my dash lights and headlights. So when I drive at night I plug it back in and everything works, except I get the same problems. It seems it only has problems during the summer months. One other thing when I go unplug the harness when I get home the wires are extremely hot to touch.
    Problem Solver:
  • 7 Answers
If its clicking it means u hooked it up correct, now read the manual n see if u have a hood switch wire. if so ground that wire and push te brakes while pushing buttons on the remote. Th e clicking sshould stop then u release the brakes and remove the hood switch from ground and it should work fine. The clicking is a way of saying welcome u installed me right!!!!! :)
Posted on May 14, 2010
  • 344 Answers
THERE IS A SHORT IN THE UNIT OR THE WIRING, I WOULD STRONGLY RECOMMEND TAKING IT TO A MACHANIC TO LOOK AT OR REMOVE THE UNIT YOUR SELF, YOU SHOULD JUST BE ABLE TO REMOVE THE 2 FUSES ON THE BIG RED WIRES
Posted on Jan 18, 2010
Why does my dashboard lights keep flickering when the car is off in my 2001 bmw 525i?
sounds like your having a problem with the ignition. its not shutting power off completly.
Feb 16, 2012 | BMW Cars & Trucks
Please can someone tell me why my door key will not disarm my 1996 olds aurora factory alarm system
Hello! There is a "pellet" in the key...A resistive pellet...Question is, have you tried another key? If more than one key has the same fault the ignition key cylinder is defective...Or the connector plug to the cylinder has dirty or broken pins/wires...However if it is just that one key a trip to the dealer to acquire a new one is in order...That connector has two wires...Colors are...Purple/White and White/Black...Send a comment...Guru...saailer
Feb 11, 2012 | Cars & Trucks
2001 olds aurora has several problems. 1. oil pressure lights comes on intermitantly 2. fuel gauge does not work 3. transmission shifts hard intermitantly
Classic 2001 Aurora problems!1) I have found the oil pressure light comes on intermittently as well. Check the oil quality and level. On mine I have not needed to do anything else.
2) If your willing, this is a relatively inexpensive repair...http://aurorah.proboards.com/index.cgi?board=nextgeneration&action=display&thread=5353&page=2
Sep 14, 2011 | 2001 Oldsmobile Aurora
I have a 20012 olds aurora that won't start. battery is not dead. turn the key and it won't crank at all.
When you turn the key do you hear the fuel pump energize? You should also see you dash lights go on, etc. If not, look to see why the IGNITION circuit is not coming on - either fuse or ignition switch.
Sep 19, 2010 | 2001 Oldsmobile Aurora
Security light comes on and car doesn.t start
try another key. if this doesnt work the wire in the tumbler assembly most likely broke and you will need it replaced. ( Ignition Switch)
Jul 18, 2009 | 1999 Oldsmobile Aurora
1999 olds aurora when you turn the key just says clean key wait 3 minutes
the key has magnet on it that may be weakening. It will have to be reprogrammed.
  1. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
  2. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
  3. Insert a new Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new key has been programmed.
Jul 07, 2009 | 1999 Oldsmobile Aurora
Electrical problem with my olds aurora lights flicker and clicking sound
you need to replace the light switch. It is shorting in the mechanism itself not the wiring. I had the same issue. Just another GM engineering blunder
May 23, 2009 | 1995 Oldsmobile Aurora
97 olds aurora wont start
did you get the tumbler from the dealer because some have coded keys
Mar 05, 2009 | 1997 Oldsmobile Aurora
Bulldog Remote Starter & T-Harness Kit for 99-03 Oldsmobile Alero; 97-99 Ol Logo
160 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
