Question about KitchenAid Microwave Ovens
HOW TO UNLOCK DEMO MODE ON KITCHENAID MODEL KRFC300ESS01
How to get my panasonic microwave model NN-H275 off demo mode
turn it on and use it the demo mode will shut off
Oct 17, 2014 | Microwave Ovens
Model KCMS1555RSS appears to be in demo mode. How do you turn that off?
Here is what I found. You can click HERE for the owners manual online, but here is the skinny
To Turn On/Off Demo Mode: Touch and hold TIMER for 5 seconds until 1 tone sounds, and "DEMO ON" appears in the display. Repeat to turn off Demo Mode
Happy to help anytime, please rate service :)
Joe
Sep 01, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
The letter d on screen.turns on but doesnt heat
Your microwave is in demo mode, which means it will not heat. To turn it off touch and hold TIMER SET/OFF for 5 seconds until 2 tones sound and the "d" disappears on the display.
Aug 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
It keeps on showing demo and we dont know how to get it started again
Depends on the model but here is a video for one model: http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportHowToGuideDetail?storeId=15001&idval=UCM_STG_CNT_037074&catname=Microwave+Ovens&title=How%20to%20deactivate%20the%20Demo%20Mode
In most Panasonic models, the DEMO mode is turned on or off with "Fn + 5" key combination. So if you are stuck in Demo mode, press Fn followed by 5 it will bring you out of it. Other times, it could be Fn + 0 and then Press 1 to turn on the demo mode and 2 to turn it off.
If there is no Fn key on the touch pad then it could be something like tapping the ON or OFF key four times
Jul 17, 2011 | Panasonic Microwave Ovens
Demo mode will not turn off
If the model number you have this listed under is correct, all you have to do to turn the demo mode on/off is the following:
Press FUNCTION, followed by "0" (zero), then press 1 to turn demo ON, or press 2 to turn demo off.
If this is not your model number, please post back with your correct model number, so that I may be able to assist you better.
NOTE: These instructions are listed on pages 10 and 11 of the Owner's Manual.
If you no longer have an owner's manual, you can download one for FREE at managemyhome.com. Just go to the "Manuals" link and type in your model number.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Aug 22, 2009 | Panasonic NN-P794SF Microwave Oven
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
Stuck in Demo Mode
I will need a model and serial no to further assist you
Jun 19, 2008 | GE CVM2072SMSS Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
DEMO MODE
how do i change the bulb inside the microwave ge xl 1800
Feb 13, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
99 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
