Question about Blenders
Robots coupe stick blender mp240 not. Powering on
Robot coupe jucier machine need price quote
we do not quote any prices here . this is a repair help site
Dec 19, 2015 | Robot Coupe Blenders
Disassembling a robot coupe mp450
First you drill out the plastic plugs to acess the torx screws holding the housing together. Remove 4 motor mounting screws to separate from shaft.
May 28, 2013 | Robot Coupe MP450 Handheld Blender
You have to drill out the little plastic plugs to get to the torx screws holding the housing together
Jan 18, 2013 | Robot Coupe MP450 Handheld Blender
I need a wiring diagram too don' Robot Coupe have service info. on their products as expensive as they are it's a problem. Robot Coupe MP450 Turbo can't seem to find anywhere. Thanks
Jun 02, 2012 | Robot Coupe MP450 Handheld Blender
we found the solution to the problem on your website.
Thank's for the tip.
Feb 15, 2010 | Robot Coupe MP450 Handheld Blender
I have a stick blender. How do I attach the flat
if the whisk attachment looks like the bottom part of your blender- the bottom part, with the blades, is probably detachable, and you can grasp it, and turn it counter-clockwise to detach it, and connect your other attachment by locking it in clockwise! just a guess!
i have one, but no added attachments-but can remove blade part to clean it- as i stated- just a guess!!
good luck!
Oct 09, 2009 | Blenders
Blender suddenly stopped working while in use, lights are on
The motor has burned out. Check with the manufacturer about warranty status for the blender or exchange it.
Jun 23, 2009 | Kenmore 204101 Single-Speed Blender
Does any one know how to dismantle a blender mp 450 robot coupe?
4 screws are covered by caps in the handle area, everyone finds these but there are a further 4 screws found by removing the air vent grilles. The grilles are held in place along their shorter sides midway. Pop a fine screwdriver in at this point and the grille comes off.
Jun 03, 2009 | Robot Coupe MP450 Handheld Blender
Robot coupe mp 450
Hope this helps you can download it by PDF
May 22, 2009 | Robot Coupe MP450 Handheld Blender
If you type in your model number on the internet information will come up on it for parts & other things. Hope this helps
May 04, 2009 | Robot Coupe MP450 Handheld Blender
Blenders Logo
91 people viewed this question
Top Blenders Experts
Are you a Blender Expert? Answer questions, earn points and help others
