Question about Yamaha RX-797 Receiver
Yamaha RX-730 Display Does not Light Up
I have the very same issue. I am the original owner of a RX-730 receiver with a non-functioning display. I am not sure when it went out, but the unit has been sitting on a shelf in my basement for at least 16 years. Ipulled it out, and can't believe how much better the tuner works than a couple of Sony's that I have had in the interim. Therefore I am motivated to get it fully functional again because it's kind of hard to tune without a display!
It doesn't look like a cheap fix though. It will probably need both a display controller board and the display itself. I think that the display is ok, but it has about 50-60 solder joints to the board that would have to be undone. It seems like it will be easier to just solder up a couple of new parts which will cost $$$.
I'm searching for a service manual right now and I'll update the post when I get it figured out.
The display is backlit with an incandescent bulb an easy fix. Two wires from power supply to a white plastic hollow reflector assy, similar to the back of an auto headlight assy. unplug at pwer supply and remove bulb from reflector insert new bulb and your done. Be careful not to damage pc board above reflector it's the controller for the LCD dislplay.
Posted on Nov 18, 2009
Cd snit is right, it's really easy to do just plugs in like a car headlight. i have the same problem with mine. backlight bulb burns out. (no setting to turn display off on this old unit). i replaced the backlight once with a small light bulb from radio shack but it quickly burned out the new one too. i'm pretty sure the the circuit feeding the bulb is hinky & it surges on power up & blows the bulbs. we've just gotton along without the display as we only use the old thing for occasional listening.
Posted on Dec 19, 2009
  • marty k Jun 13, 2012
    ok so after the wife was complaining about not being able to see the display i took some time to figure out what kind of bulb would work in this thing. found out that a 12v automotive bulb does the trick. measured voltage was just under 9v (after i toasted the resistor in that circuit by trying to measure the current the wrong way). anyway, i connected a type 37 bulb (12v dash light) and it seems to be working ok now for the last 2 weeks. i was worried about the heat generated by the bulb so drilled a couple holes in the white plastic shroud for ventilation.
  • ximuhonorsoc
    ximuhonorsoc Jun 14, 2012
    After I got hold of a service manual, I was able to determine the specification on the bulb and find a suitable substitute that plugs right into the backlight reflector. My replacement bulb has been going strong for almost three years now without any issues. I've got a few extras, so anybody stumbling across this post can contact me at mfw @ mechanova (dot) com and we can work something out. Put a period in the email address where the word dot is spelled out
    President:
  • Yamaha Master
  • 1,114 Answers
Have you checked the settings on the receiver? You can turn the display "off" on many Yamaha receivers. If you don't have the manual, post a comment and I will PDF one to you. Hope this helps
Posted on Jul 26, 2009
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Nov 09, 2009 | Audio Players & Recorders
Display panel does not light; sound is ok
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. http://www.yamaha.com/yamahavgn/Documents/YEC/Stereo_Receivers/Manual/RX-797_e_U_p.pdf That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Jun 02, 2009 | Yamaha RX-797 Receiver
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Feb 22, 2009 | Yamaha RX-V730 Receiver
No auto setup display on TV
For the setup functions you have to use either the monitor out (a yellow jack on the top-right corner of the back) or you have to use component video out. HDMI will NOT work for setting up the system. This is one complaint to Yamaha from all of us.
Feb 14, 2009 | Yamaha RX-V661 Receiver
Have tried a chat session with "classyexpert" re: Yamaha RX-V663 a/v reciever a number of hours ago. Session was terminated due power failure other end. Was invited to wait for further assistance but...
Hi and welcome to FixYa,
Have seen a lot of similar issues here at the site and on the field.
I have posted in your original problem, excerpt below:
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Then the non functional HDMI could be attended to at your convenience. Technically, it would appear to the the HDMI signal processor of the receiver.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 20, 2008 | Yamaha RX-V663 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Feb 05, 2008 | Yamaha RX-V620 Receiver
RX-V1500- front panel lights not working
The display on an amp has two components.
A small Lamp (light bulb)
A LCD display with a color filter.
Normally when the display goes out the problem is with the lamp
The lamp on my RXV 870 died after about 9 years of use.
I called Yamaha and was able to by a replacement.
The lamp is an odd voltage 14.5 if I recall.
Looking at the receipt i should have bought 3 for the cost of shipping. It cost about 10.00 cnd,
Apr 02, 2007 | Yamaha RX-V1500 Receiver
Open Questions:
See all Yamaha RX-797 Receiver Questions
Yamaha RX-797 Receiver Logo
1,515 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
