Question about Cameras
Need to put software on z10 secrity wipe was interrupted
How to restore blackberry z10
If you went to Settings, Security and Privacy then Security Wipe. The Balckberry will reload and reboot itself, but you will have to set up the wifi again as you will have wiped out the wifi settings and your Blackberry ID. You need to treat the Balckberry as a new unit and set up both. You can use the ID you set up originally. If you are not the original owner you will need to set up a Blackberry ID.
Nov 21, 2014 | Blackberry Cell Phones
UNLOCKING OF MY DEVICE
Use your desktop software to backup your data then reload the Z10 software.
Nov 21, 2014 | Research In Motion BlackBerry Z10 GSM...
Dimage Z10 won't read card
What type and size card? The Z10 uses SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jun 29, 2013 | Photography
What size sd cards can I put in my fuji z10. Is there a limit on the size
The maximum memory size for the Fuji z10 is: SDHC card 8GB
any other questions, XXXXXXXXXX
Jul 31, 2011 | Fuji FinePix Z10fd Digital Camera
Can the Dimage Z10 be used as a webcam
Yes it can, most definitely. BUT do you really want to waste an expensive camera on something a proper Webcam can do?
Using your camera as a webcam is like using a Rolls Royce as a Pizza Delivery van, it does the job but it's a bit expensive.
Running your camera will obviously make it generate heat and heat over prolonged periods can affect fragile circuitry. Especially the CCD. Lost pixels is one problem and complete failure is another. I have a Z10 but it's been in a box downstairs for about 3 years. As I'm an invalid I can't get to it without getting someone to go searching (for hours)
Honestly, I'd rather advise you to buy a dedicated webcam which comes with the software required and runs out about $30.00 or less. OK the picture quality won't be as good as your Z10. Another problem is, where are you going to mount it? What software will you use to operate it as a webcam? and do you really want to tie up an expensive piece of equipment taking continuous pictures of yourself.?
If you insist on using the Z10 then you will have to check whatever software you use to chat on the Net has the ability to use a webcam. I know MSN does and just for test purposes I've used a digicam on MSN. I was told the received picture was good. If you intend actually talking as well then I'm not sure but I think you'll need a seperate mic as the internal camera mic is disabled except for movies. Sorry, I'm relying on memory here. I loaded my library of manuals but didn't find any mention of webcam use.
Try a shareware site for software to use for webcam and it should be a simple matter to plug your camera into the USB port using the supplied camera cable and switch your camera to, believe it or not, camera.
Simply getting your face on the screen isn't sufficient, it has to be shown within the webcam box.
So I'll advise against using the Z10 but if you must, you must. If you have any problems setting it up I'll get mine retrieved from downstairs and work it out for you.
Apr 14, 2010 | Konica Minolta DiMAGE Z10 Digital Camera
Optio Z10 beeps 4 times and shuts itself off 3-4 seconds after turning it on
Your problem may be due to a weak/worn out battery or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your battery may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 04, 2009 | Pentax Optio Z10 Digital Camera
Can't install software for Pentax OptioZ10
If software is a problem why not just buy a USB to SD card adapter, and plug your SD card directly into macbook - about $10
Mar 08, 2009 | Pentax Optio Z10 Digital Camera
I brought my PS3 to my friends house and put in the Grand Theft Auto ivdisc but before the game showed up there was a screen saying that afile needs to be downloaded before i could play the game. My...
PS3 may have been doing an update of some kind and you have interrupted it and damaged the system software.
You might be able to download the system software and install it back back it will most likely wipe everything saved on your ps3.
Not sure how to do this as I have never turned off the power during an update ?
Found this site not sure if it will help
as it does not explain how to install the software onto a ps3
https://www.playstation.com/en-au/get-help/ps3-system-software/
but this you tube video explains how to do it
https://www.youtube.com/watch?v=a5OIZ73U7v0
Also you could have instead interrupted a need for speed update. It needs to update to play in network mode .
Apr 30, 2017 | Sony Playstation 3 (PS3) Console
Motorola Z10 stock firmware needed
http://www.skinnermania.com/forum/uploads/firmware/Rizr/P2S721_U_50.10.F2G_00000a87_3191u_Z10_Swisscom_SE9787AXXP.rar I tried this and it works, I am currently running this on my Z10
Oct 01, 2008 | Motorola Mobility Z10 Smartphone
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
