Question about Home
Why don't the hands on my chime clock move ?
I initially got the time set on my Tochigi Tokei Westminster. Thanks to the advice I got from this site! So now it keeps pretty good time because it chimes the right amount of chimes when it is supposed to, but the hands don't move. So I would just like a little advice before I start taking the hands off or tearing anything apart. Thanks for being out there.
2 Suggested Answers
  • 45144 Answers
SOURCE: does the pendulum swing have anything to do with keeping time? On a tochigi tokei wall chime clock model882-1285 ?
Yes, it does
Posted on Dec 02, 2016
Daniel Dakota Westminister Chime clock not keeping time. The pendulum moves but the hands do not. Any idea what is wrong? Thanks! Donna Hartman
Hello, Donna -
I found and looked through the owner's manual for the Daniel Dakota Westminster Chime clock:
https://secure.img1-fg.wfcdn.com/docresources/23391/13/139903.pdf
If you have not already done so, you may wish to insert fresh AA alkaline batteries in the clock. (Page 4, Image 9 of the owner's manual in PDF format) Follow those directions.
Then, look on Page 5 [Image 7, PDF document] regarding setting the time.
Step #8 states:
Never turn clock hands counter clockwise as it will interrupt the chime sequence and damage the clock.
Did you or do you know if someone else reset the time on the clock by moving the clock hands counter clockwise? If so, that is the cause of your problem.
A local clock repair shop may be able to fix your clock, or tell you if it is worth repairing.
Jan 05, 2018 | Chime Home
Trying to find a replacement motor for a wall clock. It takes TOCHIGI TOKEI CO. LTD NO (0) JEWEL 22903A 0101E ?
Sorry this site does not sell parts or have any references to look them up other than a search engine like Google.
Nov 16, 2016 | Audio Players & Recorders
My Howard Miller wall clock Westminster chimes is one hour off. ie: It chimes twice at 1:00 Any suggestions? I have it for at least 25 years and never had this problem before. Thanks! Stacy
Gently move the hour hand to the 2 O'clock position, then using the minute hand cycle the time forward until it is at the correct time.
Tim
Main Page
Jan 06, 2016 | Home
Setting tochigi tokei co quartz westminister chime
the 2 hour buttons and 2 minute buttons represent a 24 hour clock ie 2:55 is 1452 hours so press first hour button onces the second hour button 4 times then the first minute button 5 times then the second minute button 2 times
Nov 25, 2012 | Seiko Mantel Clock
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Apr 05, 2010 | Seiko Mantel Clock
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
