Question about Home
My clock is still having the same issue because I havnt go the right answer yet. It keeps time but the hands don't move I mean it chimes on the hour like its supposed to.
  • 277 Answers
Take it to a clock repair shop, sounds like a worn or damaged gear.
UsedClockParts.com
Posted on Jan 04, 2017
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
How do I synchronize a Grandfather Clock to chime correctly on the right hour?
Count the number of times the clock strikes, while leaving the minute hand pointing at the twelve, move the hour hand ( short hand) to the number it struck. ( this is the only time you should ever move the hour hand yourself). Tighten the hour hand by pressing the hour hand in towards the dial just a little. This can be done by placing a thumb nail on each side of the base of the hour hand at the center shaft. You do not want the hand to touch the dial. Now run your clock up to a quarter after, and let it chime. Now the half hour, the third quarter, and finally the hour. It should strike the correct hour if done correctly. Short version, move minute hand(long hand) to twelve so that it's pointing straight up. 2 move hour hand(short hand) back one hour. 3 tighten hour hand by pushing in toward dial. 4 check the function by advancing the clock one quarter hour at a time letting it chime in between quarters, then counting the strike on the hour. Hope this helps, and not confuses. Good Luck
Mar 02, 2015 | Home
My clock chimes out of secrence quarter past then hour chime is quarter to hour? how can i fix please
Sounds like the minute hand is a quarter hour off. Make the clock strike on an hour. Count the number of times it strikes, then remove the minute (long) hand, and the hour hand. Replace the hour (short) hand to the number that the clock struck, and tighten by pressing hour hand in toward the dial, then replace the minute hand in the position that it's pointing at the twelve. Now it should be showing the time that it struck. To make sure, advance the minute hand to the half hour, and let it strike the half. Advance it to the next hour, and it should strike the correct time that is showing on the clock. For example, if the clock strikes four, and is showing three, then move the hour hand to the four while the minute hand is pointed at the twelve, then press the hour hand on each side of the center shaft towards the dial to tighten it. Now advance to half hour, and let strike, then advance to the next hour. It should strike the correct hour. I hope this helps more than confuses. Good Luck
Feb 08, 2015 | Home
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Nov 06, 2011 | Seiko Mantel Clock
How to syncronize time with clock chimes? Howard Miller banjo clock.
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
May 09, 2011 | Watches
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
Our wall clock was not wound a couple of months ago (it is a chime clock that chimes on the hour and half hour with weights) and when we rewound it, everything works fine except that the chime is out of...
You were not very specific about you clock description, Many of the German clocks were using auto correct features.
You may not have this function.
Move the hour hand to the correct hour.
Hope this tip help you.
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Watches
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Feb 08, 2010 | Seiko Mantel Clock
Home Logo
111 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
