Manual for martin fireplace insert model uf298/auf29b
4 Suggested Answers
dchumky
SOURCE: ccocker319@aol.com
dchumky@yahoo.com my emil accawnd
Posted on Apr 03, 2014
  • 49170 Answers
SOURCE: Can I burn wood in my Martin Industries Gas log fireplace model number DBB36?
probably not as the unit is not constructed for wood fires
read you operators manual
Posted on Nov 28, 2015
  • 41738 Answers
SOURCE: I need the part # for the gas valve for my Martin gas log insert. Model#UF29b/AUF29B
Martin might be able to furnish the part number.
Posted on Dec 07, 2017
Martin fireplace gas insert
Clean pilot light change thermocouple might be burnt out
Jan 12, 2018 | Heating & Cooling
Martin DV4500MH fireplace manual.
Try going to manualsbrain.com I seen that they had Martin fireplace manuals just not sure if i had the correct model from you.
Jan 08, 2018 | Heating & Cooling
Nov 28, 2015 | Home
Majestic DVR 36 RN gas fireplace pilot flickers when ignited, eventually gets to full pilot. Ocasionaly burner shuts off, pilot remains on. Also, need owners manual for part numbers. Help.
Does your fireplace have a thermostat connected? If so, that may be why the pilot stays on and the burner goes off. Otherwise, it could be a bad thermopile. If that is the case, I recommend you just replace the entire pilot assembly. It is an older model and manuals can be hard ti find. If you still have trouble, I recommend you contact a local certified gas appliance technician.
Jan 12, 2014 | Majestic Fireplaces Majestic Topaz 20ILDV...
Vermont casting fireplace vcef33
You could take a table lamp or a drop light a electric drill or anything similar,and see if you can unplug the insert and plug one of these items in and see if the plug works
I am taking for granted that you can get to the plug without having to pull the insert out or at least not all the way out
If you can't do that
Turn the breaker off to that circuit pull the switch out and make sure nothing is touching
Hook a tester to the wires and then turn the breaker on and see
If you have power to that switch turn the switch off and on watch the meter and see if it does turn on and off
If you have power coming out of the switch.
and you can't reach the plug then you only option would be to pull the insert
As for a fuse there may be one but not look like what you are thinking a fuse will look like it is usually a temperature fuse that is shaped similar to a diode the symbol for it can be two ways
it could have what looks like a c laying on its side upright and also another c beside it on its side aiming down like a snake crawling. The other symbol looks like a rocket with no fins on its side with a with a what looks like a T laid sideways coming off one end
Oct 20, 2013 | Heating & Cooling
As fireplace turns in the reverse of the gas insert. Can you please help?
Google make and model number you should find a manual you can down load in a pdf .
Oct 13, 2017 | Heating & Cooling
Ccocker319@aol.com
Try fireplacesandwoodstoves.com
They have a full line of Martin products.
Hope this helps.
Oct 13, 2009 | Sport & Outdoor - Others
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
