Question about Garden
My tine came out of my kalimba - Garden
Tiller runs great just having a problem with the tines turning plowed my garden last week and for some reason the tines quit turning like its locked or something please help me
Two possibilities. Something has jammed the tines.
Pull the spark plug wire off and tuck it away someplace so as not to touch the plug.
Tip the tiller up and examine the tines for obstacle such as a rock. If there is nothing jammed try to turn the tines by hand. If the they turn freely you most likely broke a shear pin that secures the tines to the axle.Clean the axle and tines and examine very closely for the pin.
If sheared ( broken) you will need to drive the broken piece out and replace the pin.
There may also be a problem in the transmission case. You would need to remove the tines and case to open it
Apr 01, 2016 | Garden
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Broken tines on honda tiller fr650 model need part numbers for left and right tines, or location near or in Concord NC I can purchase them.
I will supply you with the part no. I have:
06722-777-000 TINE KIT, ROTARY
72100-777-013 TINE ASSY., R. (OUTER) Use up to Frame SN 1021912.
72100-777-023 TINE ASSY., R. (OUTER) Use from Frame SN 1021913.
72150-777-003 TINE ASSY., R. INSIDE Use up to Frame SN 1021912.
72150-777-013 TINE ASSY., R. INSIDE Use from Frame SN 1021913.
72200-777-013 TINE ASSY., L. (OUTER) Use up to Frame SN 1021912.
72200-777-023 TINE ASSY., L. (OUTER) Use from Frame SN 1021913.
72250-777-003 TINE ASSY., L. INSIDE Use up to Frame SN 1021912.
72250-777-013 TINE ASSY., L. INSIDE Use from Frame SN 1021913.
Hope this helps. Make sure you verify the frame serial number. The tine assy. include the hubs and mounting hardware.
Feb 24, 2011 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
I have a Troy-Bilt PTO Horse (Horse III) 8HP TINES
The tines are very close to the housing and sometimes you do get rocks hitting,as for the dirt it should have side panels to keep the dirt in place.
May 07, 2009 | Garden
Wheels turn, tines don't
These machines have an arm to activate the tines independantly from the wheels, make sure that the tine arm is in the on position.
If not, seems like you have a transmission problem, you'll have to get dirty to fix this one and open up the transmission casing to see if its just the link between the tine arm and tine crankshaft that broke or if its more serious.
Apr 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
