Question about Carrier Heating & Cooling
Is it correct that Carrier had 5 year waranty back in 2007?
I have a Bryant/Carrier Evolution 96 with Infinity controls. Installed 2007. Currently the Inducer won't start every time.....but does eventually. I'm told $1250 for new Inducer installed since Carrier only had a 5 year warranty. Is this correct? Anybody have any thoughts on lowering the cost of the Inducer replacement?
  • 1,711 Answers
Try looking up your own warranty. Check carrier warranty on your model and serial number located on data plate on machine
Posted on Dec 10, 2016
Zone control not working
These are both power open and closed. Yellow and green should be constant on the leds. C&D is your 24 volts for the controls. If you got power going in but nothing coming out of the board it is bad. If you got 24 going to the damper but damper not responding obviously it's bad. Usually communication is DC voltage, likely 12 or 13 DC at A&B. Good Luck!!
May 13, 2017 | Heating & Cooling
We have a Carrier Infinity 96 furnace in our home, which was installed brand new in our house we built 5 years ago and this thing is a nightmare. We've had the code blinking away and and the technician in...
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST DIGIT DETERMINED BY THE
NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY THE NUMBER OF LONG FLASHES.
43 LOW-HEAT PRESSURE SWITCH OPEN WHILE MEDIUM-HEAT PRESSURE SWITCH IS CLOSED - Check for:
- Low inlet gas pressure (if LGPS used).
- Plugged condensate drain.
- Improper pressure switch wiring.
- Water in vent piping, possible sagging pipe.
- Stuck open low-heat pressure switch.
- Disconnected or obstructed pressure tubing.
Mar 28, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Shopping for a new AC. Looking at Carrier Comfort
For the money might want to look at a ruud or reem carrier is just kind of higher in price and the warranty every manufacture carries at least 5 years on the compressor hope that helps shop around do your home work and remember any unit is junk if not properly in stalled. good luck Tom
Jul 06, 2009 | Carrier 38CKC036 Air Conditioner
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
I have carrier infinity 18 central air and worked good for one year and second year summer season its out of purion gas and we had an authorized person to recharge with purion gas and worked for a few days...
Carrier carries a 5 yr parts warranty.I'm not a big Carrier guy but the are not an inferior product from what I've seen.I'd contact another company that is a Carrier dealer for a second opinion.
Aug 05, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
