Question about Bosch Washing Machines
I can't get dispenser drawer of my Bosch washing machine out. I press down on the 'insert' as instructed and pull quite hard, but drawer won't come out. Thank you.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
You should not have to press to hard try jiggling it as you pull the soap can jam it up
Posted on Dec 10, 2016
How do you remove the fabric softener dispenser? No clip ring, does not lift up.
Pull out drawer unlock Despenser by pressing the release lever on left hand side of dispenser mine is a grey plastic stick out about 2inches press it down and pull drawer completely out. Dispenser pops out be care the grey stick (about 4inches) pops off and must be reinstalled in its proper slot. Drawer slide back naturally
Jul 07, 2015 | Maytag Washing Machines
How do I remove the top of the washing powder drawer unit for cleaning
I assume its a front loader? If so, the centre of the drawer (when open) has a clip which you push down to release the dispenser. It should slide straight out.
Mar 12, 2015 | Bosch Washing Machines
How do I remove fabric softener dispenser?
Good Morning Friend,
I understand you want to know how to remove the fabric softener dispenser from your Frigidaire washer, model# ATF6000ES. To remove the drawer, please do the following:
• Remove the drawer by pulling it out until it stops.
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
• Remove the insert from the bleach and fabric softener compartments.
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softener residue may indicate improper dilution or more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residues from the upper and lower parts of the recess.
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire ATF6000ES Front Load Washer
Fabric softener dispenser/how to clean
I understand you want to know how to clean the fabric softener dispenser from your Frigidaire washer, model# ATF7000ES. To remove the drawer and clean the dispenser, please do the following:
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
Leak detergent drawer
If the machine has been moved recently, ensure that it is level and not leaning forward. Pull the dispenser completely out (pull as far as it will go, then press down on the blue section in the fab cond compartment to fully remove) make sure it is clean and free or fab cond and powder build up. Following the diagram, check that part 0412 is clear (this can be done when the drawer is out by putting some water in the dispenser manually and seeing if it flows quickly. A baby bottle brush can be used to clear it, if it is blocked.769ae95c-736a-45f2-a40f-6dd121e32863.png
Apr 25, 2013 | Bosch Exxcel WFX 3267 Front Load Washer
My son has given me his Whirlpool washing machine but I can't figure out how to take out the soap powder dispensing drawer to clean it. Can you help?
hi.
pull out the drawer as far as you can.
in the centre you can see a plastic insert (usually a different colour to the main drawer)
you should be able to press this down and this releases the catch holding the drawer in.
it is the same sort of system you find holding a car ashtray in place if that is any help.
Apr 02, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
How do i clean the soap powder dispenser drawer? Can it be removed?
There should be a clip in the middle of the top of drawer you press this down quite hard to see it ,this then allows tray to be removed easy for cleaning
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Sirs: The Softener Dispenser on my Bosch Axxis washing machine is filled up with water. What to do? It won't dispense softener.
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK then try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spray will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Nov 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Conditioner isn't being taken in to the machine
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 16, 2009 | Washing Machines
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
