Question about Cell Phones
How to unlock an aim aft54tv - Cell Phones
I need an unlock code for my Samsung SGH-A187? My IMEI # is 352424044427538. My e-mail is amazingggxalyssa@aim.com
Hi, You can get the unlock code for a Samsung A187 from www.classicunlocking.com/samsung-a187/rs17wp9/ at affordable cot with easy unlocking instructions.
Sep 16, 2012 | Cell Phones
I have forgotten security code of my nokia 2700 classic plz give me master code to unlock it
Hello Aim,
Switch off the phone.
Remove the battery for 30 minutes.
Reinsert the battery and switch on the phone.
Enter the default code 12345.
Your phone will be unlocked
Apr 16, 2011 | Nokia Classic 2700 Cell Phone
How to unlock my camera on aim video chat
There is no support for aim video chat at this time. Tango, Qik and Yahoo messenger are the service that provide video chat support.
Feb 26, 2011 | HTC EVO 4G Smartphone
It says that i unlocked different guns in the game after i got certain kills but i cant use them in the levels an di want to use them can you help me?
1. First you must unlock new weapons by completing hunts. Once you have unlocked a new weapon it will stay with your hunter into all future hunts.
2. Go to Main Menu > Aim at Mission Select and pull trigger.
3. Scroll through all unlocked missions > Aim at any mission you want to hunt that is already unlocked and pull the trigger.
4. Before choosing which animal you are going hunt on that mission: Look at the bottom of the
"Hunt Select " page, there are Capitol Letters inside of white boxes. Each letter belongs to a different button on your Wii remote or Nunchuk. > Press only the button on your Wii remote or Nunchuk that will open: Select Firearms
( This letter is C on the top shot style, indicating the round button located right above the trigger on the Nunchuk )
5. If you pressed the right button the next page will have a picture of a weapon with three box choices at the bottom: RIFLE - HEAVY RIFLE - SHOTGUN. > Aim at the box choice you want and pull the trigger.
6. This page has pictures of all the unlocked weapons in the category that you chose. Scroll through the pictures and choose your new weapon > Aim at that picture and pull the trigger.
7. The next page will have a picture of the weapon that you chose. At the bottom of the page you will see two options: Select Firearm or Back > Press only the BACK button on your Wii remote or Nunchuk.
8. You are now back at the " Hunt Select " page. Choose which hunt you would like to go on, > Aim at that hunt and pull the trigger.
9. When that hunt opens you will be carrying your new weapon. HAPPY HUNTING!
Dec 26, 2010 | Activision Cabela's Big Game Hunter for...
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Aim on lg shine cu720 for tmobile
you would have to reflash another firmware on the phone.
Jun 06, 2009 | LG Shine 720 Cellular Phone
Aim advd70 unlock code
Take the piece of **** back to Pick n Pay. I did, I got a full refund. I told the manager that I was not informed that this AIM ADVD70 only plays Region 2 discs and I want my money back, He gave it back to me and I went to but a Philips DVP5166k DVD player, all **** stopped here. Only R600-00 for the machine.
Mar 30, 2008 | LG RH266 Recorder
SAMSUNG A737 UNLOCK CODE
I have a Samsung SGH A737 that needs unlocking as well! can someone please help! Thanks!
Mar 21, 2008 | Samsung SGH-E630 Cellular Phone
AIM DVD PLAYER 30
I have a AIM ADVD - 70 with the same problem. Who makes these this.
Feb 15, 2008 | Televison & Video
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
