Television comes on for 5 seconds then goes off for five seconds keeps doing this continually.
3 Suggested Answers
  • 84 Answers
SOURCE: sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Posted on Apr 13, 2008
  • 9 Answers
SOURCE: television keeps going off by itself
overheating.open back hoover up dust carefully.
clean air vents.make sure air circulates around tv
Posted on Mar 15, 2009
Vizio tv repair picture blurs and darkens for five seconds and then goes normal for five seconds and continues this cycle. i changed the tcon board and no change.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 29, 2015 | Vizio Razor M501D-A2R 50" LED Smart TV...
Wont turn on. on light comes on for 5 seconds then shuts off
Do the self check this model has.
When power light goes off on the front of the set press and hold both the menu and input (device) at the same time and hold for at least five seconds and release both buttons.
The power light will blink a two digit error code: like 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know by leaving a comment here what code you find and I will tell you what it means.
SD TECH
Jan 01, 2011 | Mitsubishi WS-55809 55" Rear Projection...
When the TV is powered up, it shuts off in two to five seconds.
DO THIS: when set comes on and goes off (green power light) On the front of the set press and hold BOTH THE MENU AND INPUT BUTTONS IN TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code like 2,2, a pause and repeat it up to a total of five times.
Let me know what error code and I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 16, 2010 | Mitsubishi VS-45609 TV
When you turn it on the tv stays on for 5 or 6 seconds then goes off
When it shuts off and the power light goes out do the self check this model has:
On the front of the set press and hold both the menu and input buttons for at least five seconds and then release both.
Power light should blink a two digit error code at least five times.
Most common are 2 blink, a pause and 2 blinks or 1 blink and then one blink.
Let me know what you find and I will assist you.
SD TECH
May 17, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tv problems
There are some capacitors on the power/HV deflection board that usually blow. You can actually see that they have vented on the top. Cp150 is the most common to go.
Jan 07, 2009 | Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony 2002, kpws500
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
