Question about Kitchen Appliances - Others
Russel Hobbs Toaster 13766 Carriage Lever gets stuck half way down.Any solution Toaster only one year in use
  • 3 Answers
SOURCE: Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Posted on Mar 28, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
SOURCE: russell hobbs toaster 9379 bread carriage handles
bought a new toaster I would like any account you have created for me to be deleted. thank you
Posted on Dec 23, 2009
  • 34 Answers
SOURCE: "Down lever" doesn't stay down
You can try taking the toaster over to the kitchen sink and hold it upside down. Shake the heck out of it and you may dislodge something (like an old breadcrumb) in the switch. I've had to do this numerous times. You have to flip it upright, shake it, turn it upside down and shake it again -repeat until nothing comes out and nothing sounds like it's rolling around in the toaster.
Posted on Mar 14, 2010
  • 51 Answers
SOURCE: Russell Hobbs 10617 led bar
Well.
Heres my two bob... This is not a solution but may help someone.... I copied this from my post to another question dealing with the same toaster and problems... Also, I noticed that, in simo_tomic post, he refers to the chip in question as an 63AB1B , whereas mine the label was blank or ground off.
I havent found a source for these yet. Anyway.... onto original post...
I've tried to repair one of these toasters today.
It would intermittantly work, eg led lights would work, and the toaster would actually stay down.
Most of the time however, no lights, no toast staying down.
By removing the power cord and re plugging it in, occasionally the leds would light, then the toaster would work, until it stopped again.
FIRST A WARNING! YOU CAN KILL YOURSELF IF YOU PULL APART A TOASTER, THE VOLTAGES ARE DEADLY, IF YOU DONT KNOW WHAT YOU ARE DOING DONT OPEN IT! GET AN EXPERT OR GET A NEW TOASTER.
I pulled it apart, which was a pita as they used 8x non standard screws on the bottom.
On the pcb board where all the leds are, there is a large 18 pin chip, labelled MCU.
I believe that this is the culprit, as all diodes, resisters, caps seem OK. The thermister is ok.
By shorting two of the pins on the mcu, the leds would light up, and the toaster would actually keep the toast down, and therefore work.
However, the B**stards at Russell Hobbs have chosen not to label that chip, or have ground off the label, to make it harder for people like ourselves to repair.
Plus the fact that they use security type screws to keep us out.
This should be criminal, as it just encourages waste.
For futher info, I shorted pins 4 and 5 briefly, (ie looking at the toaster, the 4th and fifth pins on the top/far side of the pcb board, counting from the right hand side).
When I short these pins the toaster leds light and it works, not a permanent fix however.
Anyone know a suitable replacement for the MCU in this unit?
Posted on Jun 16, 2010
New elements for Russell Hobbs Toaster 9276
go to an appliance repair shop and see it parts are available. go on the web--google-- russel hobbs toaster ---parts department and give your model number.
May 26, 2013 | Russell Hobbs 9276 Toaster
My russel hobbs jug kettle is leaking very badly and it's not 2 years old yet
Why would anything else fail because the kettle seal has gone? They are generally ok aren't they?
Apr 26, 2012 | Kitchen Appliances - Others
I need a user instruction manual for a Russel Hobbs RHM25L Microwave Oven
You can download the instruction manual by clicking on the following link.(http://www.russellhobbs.co.uk/pdf/product_236_14356.pdf ).Please don't forget to rate me if satisfied.Good Luck.
Jun 08, 2011 | Russell Hobbs 10617 Glass 2-Slice Toaster
RUSSEL HOBBS STEAMER
I was give by my mum a digital george foreman steamer with out mannual! I was wondering where i can get one or down load it for nothing! please help me
Regards
Janelle Cook
May 28, 2010 | Russell Hobbs RHST3 Rice Cooker
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
Aug 04, 2009 | Kitchen Appliances - Others
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Plastic knob broken on Toaster
Have you tried gorilla glue?  It is very solid but messy stuff.  be careful with it and try to clamp it some how.
Nov 16, 2008 | Russell Hobbs Kitchen Appliances - Others
REPLACEMENT CORD FOR DEEP FRYER MODEL #RHDF260A
solved my problem i do not know what my son did joan
Jul 05, 2008 | Russell Hobbs RHDF260A Cool Zone Deep...
Kitchen Appliances - Others Logo
88 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
