Question about GE 1/2 Hp Ecm Blower Motor Hd44ae121 5sme39hl0308
How to repair blower motor 1985 intertherm furnace. High pitch squeel then blower fan rumbles
  • Janice Arn Dec 11, 2016
    This blower motor question should not be catogorized as air conditioning its states it is a furnace
    Top Expert:
  • GE Master
  • 50,270 Answers
Have you tried oil on the bearings
Posted on Dec 11, 2016
  • Janice Arn Dec 12, 2016
    What do I have to take apart to oil the bearings. Or does this picture show accessibility widowed fixed income do it yourselfer. Thanks
  • ray gallant Dec 12, 2016
    there might be a place you can access it on the end of motor with a spray can of wd 40 and the little red tube ..by leaving it in place
SOURCE: furnace fan running off and on blowing cold air
Need a little more info. Does the fan never stop? Is this a gas furnace? Is your thermostat in the fan auto not fan on position?
Posted on Dec 09, 2007
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
  • 96 Answers
SOURCE: heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Posted on Dec 10, 2008
meBNme
  • 334 Answers
SOURCE: weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Posted on Jan 19, 2009
james3751
  • 614 Answers
SOURCE: Intertherm furnace/AC, fan on the furnace won't shut off.
How old is the intertherm. The old ones have fan limit switch and sometimes they stick. The new ones have a fan baord or time delay relay. They go bad from moisture and they just go bad sometimes. It sounds like you just have a shorted relay. If you think you can replace it you can get a relay at any parts store. Need the model number of unit. If not just call a service tech for free estimate. Russ
Posted on Jul 24, 2009
Intertherm Furnace Model #mmhb070abhr06. Burner lights up but shuts down after about 10-30 seconds then recycles over & over again when fan is set to auto (because fan does not cycle on when set to...
Sounds to me like it is going off on a weak high limit switch. With the fan on it will prolong the event but will not stop it. I would check all of the high limit switches. It would most likely be one close to the heat exchanger.
Apr 06, 2014 | Intertherm 56000 Btu Gas Furnace
Furance starts, runs short time, blower stops short time, then blower comes on, burner still runniing.
Sounds like you fan limit control is not set properly. Or the blower speed is set to high.
Jan 03, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace model m3rl060abw blower makes high pitched whine when running. why? how can i fix it?
not familiar with that specific model, but if it's high pitched, it is likely the induced air blower causing it. sometimes it is possible to disassemble the motor and clean and lubricate it, but the repair that most service personell will do is to replace the motor. often it comes as an assembly which includes the motor and fan.it's the easiest, longest lasting, and quickest solution.
it is possible that it is the circulating blower with a seized bearing causing the whine. if so, the bearings (and shaft) can be replaced.
Jan 27, 2013 | Heating & Cooling
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
My furnace heats up and then shuts down not kicking on blower
Your furnace is shutting off on the high limit switch because of this. You are having a problem with the blower motor. You need to check for power from the wires on the board that feeds the motor. If you have voltage, and your run capacitor is good, you have a faulty blower motor. If its a fan relay, the fan would start and run all of the time. Check power to motor right after furnace shuts the burners off.
Robert Horton
Nov 05, 2011 | Intertherm P3RA-048K Air Conditioner
The heater fan on my 98 chevy silverado stopped working... worked on high at first but made a high pitched noise and stopped all together
Run 12V directly to the motor and see if it will run, if it dosent than the motor is bad, if it does than the resister is bad, the resister makes the blower run and also regulates the speeds for the blower, but chanses are if it was making a high pitch squeel before it quit the motor went out.
Dec 10, 2009 | 1999 Chevrolet Silverado 1500
My intertherm furnace (old model) has recently getting quite loud and clunky during its heating cycles, sound like the blower maybe??
Your blower motor has several speeds to it and by the problem you are having it sounds as though the blower motor may be going out. The motor has a slower speed for the heating cycle and since you have the noise in the heating mode I suggest having the blower motor changed as soon as possible since it could cause other problems in the heating section of the furnace( possibly burning out the high limit switches). Good Luck on your repairs hope this helped
Dave
Oct 20, 2009 | Intertherm P3RA-048K Air Conditioner
Blower speed
Yes usually the black is high speed, the blue is low and red medium speed. plug the black wire from the fan motor to where the blue wire is, then put the blue where the black wire was
Jan 10, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
GE 1/2 Hp Ecm Blower Motor Hd44ae121 5sme39hl0308 Logo
62 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
