Question about Starrett Measuring Tools & Sensors
How to install the batteries in a Starrett 723-6
Where do I get a battery for starrett digitape D3-16
send code of battry store they will reply soon
Oct 11, 2014 | Measuring Tools & Sensors
What is the correct battery for the starrett 723 electronic caliper
If small button cell then sr44 battry& if big button cell use cr2032
Jan 25, 2014 | Starrett Electronic Caliper
Starrett no 731
Are you certain the battery is installed correctly? Many electronics won't work if the battery is installed backward/upside down. Do not ask how I know this....[-:
Jan 15, 2014 | Cars & Trucks
The display is always on when I insert the battery- How do mI turn it off?
I installed a larger 3 volt battery and put a micro switch on the positive side.
Nov 19, 2013 | Starrett D125 Digitape 1Inch x 25...
Shut down starrett 733
On some Starrett calipers, there is no way of turnig them off, which means about once a year you have to replace the battery. sorry
Jan 22, 2013 | Starrett Electronic Caliper
How do you change batteries in the starrett 3752 heighth gage. I dont have a manual or intruction book
Hello rdm56us, Sorry for the delay but copy the follow link for change your battery, you have need 2 CR2450:
best regard
Apr 28, 2011 | Starrett Garden
I just aquired a Starrett 721 digital caliper that wouldn't turn on. Took cover off and batteries were in reversed polarity. New batteries didn't help. Is the display fried?
More than likely. But to make sure: check that new battery is good (voltmeter). Check with ohmmeter across the battery contacts - should read few hundred ohms to few kiloohms. If OK, reinseret battery. Push ON button. Push reset button. If go, congrats. If not, get another caliper.
Dec 07, 2009 | Starrett Electronic Caliper
Starret 734 Caliper will not power up
OK, I fixed it! After hearing back from Starrett, it seems that a RENATA battery is the only one that fits right. I went out to Radio Shack and checked their stock, which turns out to be manufactured by RENATA. The new battey works fine... It did take a try or two to get the display cleared, then Error04, now it's working again.
Mar 25, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Measuring Tools & Sensors Logo
89 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
Vernon Taylor
ray gallant
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
