Question about Dryers
Dryer qquite working.
Hi I have a Roper dryer Model rex5634kq1. it worked fine this morning and then we placed another load in and it would not come on. I am getting power to all sectors of the setting dial. but nothing to the push button starter.
  • 6,784 Answers
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Posted on Jul 20, 2009
I have a roper rex5634kq1 the heater shorted and i replaced it but the thermo cut out is stopping it from getting 230 volts is the thermo cut out normally closed or normally open this one had no...
normally closed on any thermal cutout this is to make the circuit to operate the dryer till it overheats,then the thermal opens to shut off current to the heating element for safety
Sep 10, 2011 | Roper RES7646KQ Electric Dryer
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
My Roper REX5634KQ1 will not start. I finished a load and when i put the next in it would not start. I have checked the braker box and it is still on, I cleaned lint from the back and checked for any...
there is a onetime fuse in the back that burns out and the dryer will not stsrt until you replace it is small white fuse with 2 wires attached
Sep 21, 2010 | Roper REX5635E Dryer
Roper,model# rex5634kq1 Just quit working. wont turn on or anything
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Roper Dryers
I have a roper REX5634KQ1 won't turn on!
Thermal fuse is the problem , located on the blower housing . (small white thin piece with 2 wires attached ) Pt# 3392519 . You will have to remove the front panel to get to it .
Jul 13, 2009 | Dryers
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
I have a Roper Dryer Mod# REX5634KQ1. It just
There is a "one shot " thermostat that is probably blown. Part number 279816 which is a two piece kit. The part is located at the top of the heater housing.
Apr 07, 2009 | Roper REX5635E Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
