Question about Kelvinator Dishwashers
How do I fix error 4 on my dishwasher kelvinator KD12DW2 asap
  • Timothy
    Timothy Dec 10, 2016
    Its urgent people please
I have just reeived a Kelvinator dishwasher KD12WW. I have only a cold water outlet can I still wash with it
I found a site that is important for you to down load the site is ns323666.ip-37-187-156.eu
It is a pdf version of the instruction manual for the dishwasher
I notice that one of the instructions is quote" when using your dishwasher , you should prevent plastic items from contacting the heating element" un quote
most all dishwashers heat their own water above what human hands can stand so from that statement you can use cold water inlet only and the machine will heat it to operating temperature
I got that site by going google and typing in --kelvinator kd12ww dishwasher
then I selected site manual-kelvinator kd12ww dishwasher clicked on that and that address came up with the pdf manual
there are other sites that have parts manuals and heaps of other information
call your local kelvinator service agent and ask them about a heating element
Sep 30, 2016 | Kelvinator Dishwashers
User manual for kelvinator extreme clean KD12WW
Need to check if Rinse Aid is not exhausted in the dispenser. It could also be necessary to increase the flow rate of rinse aid. Also make sure the dishwasher is heating water as some dishwashers use steam to dry. If heater is faulty the steam will not be there.
Apr 21, 2014 | Kelvinator Dishwashers
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
A KD12DSS-2 KELVINATOR DISHWASHER WITH FAULTY ERROR 4 CODE
Hi.
Error 4 is internal leakage (overflow).
when this happens often the dishwasher starts with the pump running continuously.
Switch off the power from main circuit breaker, drain the inside of the appliance and clean the drain filter in the bottom panel of the tub. If problem persists, check the drain hose at the back. Ensure that it is not kinked, and that height is as from installation manual.
If that does not work, then the machine is faulty. Repair is done removing the kickplate at the base of the appliance, checking for water leak in there. Disconnecting pump hose and removing debris, testing the overflow switch by running a cycle with its contacts jumped. The inlet valve must also be checked to ensure that it is not leaking.
Turn off power and remove water from inside the appliance. Usually that is enough to sort out the problem.
Regards.
Ginko
May 15, 2011 | Watches
We have an Error 4 on our KD12DSS-2 Kelvinator Dishwasher, the manual says that there is to much water in the machine, how do i go about cleaning it out, so the error can go away?
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drainhose is the one that leads from the pump to the underneath of your kitchensink. 5 Point the hose into your bucket to drain any debris. Twist and scrunchthe hose to help remove the waste. 6 Test the hose by running water through it,and then reattach your hose in the same manner in which you detached it fromyour dishwasher.
May 13, 2011 | Dishwashers
Kelvinator kd14ss
This is a common problem with this machine. Per the manual E4 indicates that the machine is overloaded but this is incorrect. The machines has actually become water logged due to a design fault whereby some water is allowed to pool at the bottom of the machine rather being efficiently drained. Note that the area where the water pools is not rust resistant. To temporarily overcome the E4 error, tilt your machine backwards and the excess water will drain out the back corners. Remember to put some towels down to avoid a big mop up operation afterwards. I live in a coastal area so drain the machine this way once a month and then open up the back of the machine (don't do this if still under warrantee) to dry it out completely to minimise the rust.
May 26, 2008 | Kelvinator 24 in. MDB222RB Built-in...
Dishwashers Logo
43 people viewed this question
Top Kelvinator Dishwashers Experts
P Scarbs
Level 1 Expert
paul
paul
Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
