Question about Vehicle Parts & Accessories
Radar RPU-015, in H-UP motion, head line OK but picture is in opposite position.
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
TechnoMarine
  • 132 Answers
SOURCE: Furuno Radar Model 1833C
You have two things that orient the radar, on is called heading (or bearing) alignment. This is where you aim your radar so that a target comes up at 12 o'clock when dead ahead. Access this mode by pressing and holding menu duing power on, and go in to Installation Mode, radar setup, next page, align heading. I have posted a "tip" on this, search for VX2 radar alignment.
After this is done, North up is accomplished by having a magnetic input (fluxgate compass or autopilot). Calibration of this compass varies, but if it is accurate, then all should line up nicely.
Posted on Jan 18, 2010
I just want to you that how manny salary provide to complete cisco ccent exam ,m
ok sir ..
step 1: My 1st Reason for Re install Windows Xp 2.RPU 3.1 not working.
So I am bhuvnendra re install windows xp2 this machine.
Step 2: install java+RPU 3.1
Step 3: SATA DVD drive disconnect .
Step 4: ON the system
step 5: safe mood black screen are display.
Step 6: any mood select booting o.s
Windows continue restarting.
my solution
Step : SATA DVD drive connect
system are properly booting and proper working.
please give me what is real problem in this machine.
Oct 13, 2012 | Cisco Advanced V3 Ccent Ccna Ccnp Home Lab...
Tip
Furuno VX2 Radar heading alignment
Please take the time to rate this tip!
This tip applies to all VX2 radars from Furuno. Models Include 1724c, 1734c, 1824c, 1834c, 1934c, 1944c, 1954c, 1964c, 1724cnt, 17234cnt, 1824cnt, 1834cnt, 1934cnt, 1944cnt, 1954cnt, 1964cnt, and 19XXBB series black box radar processors.When the picture is "crooked", "rotated" or "needs re aiming" you need to do the radar heading alignment. In order to do the radar heading aligment, you must access the installation menus, available only in installation setup mode.
Press and hold "MENU" during power on.Continue holding menu during start up, at least until the boat appears.
Choose , "Installation Mode", Choose "Menu", "System Configuration", "Installation Set Up" "Radar Set Up".
Here is where people get lost! Choose "Next Page", Choose "Heading Alignment". You will be prompted to place the dotted line on a target "dead ahead". Follow instructions and then, do not forget to press "SET". Press Return Return Return or Menu to exit and resume normal operation.
Note that the installation menus disappear if they are not accessed for five minutes!.
Please take the time to rate this tip.
That is all there is to it.
Please "Optimize Radar Video" in same menu (Radar Set Up).
847-746-0100
www.technicalmarine.com
on Jan 17, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
When setting the points, I think the gap is set at .015 is that correct? Do you set the points when they are on the high or low side of the lobe ? ed
Yes, the point gap is .015
There is a line etched on the face of the point cam. This lines up with the rubbing block (cam follower) of the points. This is the position that the gap is set at.
Jan 31, 2011 | 1970 Triumph T 100 R
Not getting power
Fuse in the power cord ok? Fuse in the vehicle's ligher socket ok? Does the lighter socket power other devices? Power switch is in the "ON" position?
Check these steps first.
May 20, 2010 | Passport 8500 Radar Detector
NEED TO TIME CAMSHAFTS PLEASE EXPLAIN. THANKS
Flats of all four cams on the ends opposite gears need to be parallel to top of head where cam cover bolts on. Dark links on transmission side of cam gears should line up with pins at 12:00 positions on cams. Dark links on pulley side of gears should line up with marks on intake gears. Dark link on balancer shaft gear lines up with tooth at 5:00 position. Dark link on crankshaft gear lines up at 4:00 position.
Here is a diagram of the pulley side marks.
Here is what the marks look like on the tranmission side of the gears on the front head:
Find more pix on the head gasket page of 99intrigue.shutterfly.com
Mar 09, 2010 | 2000 Oldsmobile Intrigue
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Hello there, I have a 4' radar antena with a
ahh, this is an old one check the book.(ha, ha)
Press and hold menu during start up Choose "Installation Mode" Press "Menu" Select "Radar Set Up" Press "Next Page" Select "Radar Heading Alignment" Use knob and follow prompts, you will place the dotted line at dead ahaed and the
Select "Set"
Also, remember to TUNE VIDEO
Oct 08, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Jul 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno navnet 1723 C
go into installation mode (hold menu during power on) find radar setup, go to next page, do heading alignment. also tune video, your unit was reset!
Jun 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
