Question about Honeywell Audio Players & Recorders
Honeywell 6150 display code 10
Display alarm sounding
If keypad displays the FC code Can you still program a new master code?
I have never tried that because it has never been requested. "FC" is a higher priority. It means failure to communicate. So I would always correct that problem first and then change the master code. But I don't see why you would not be able to change the master code due to FC code. Gl.
Jan 31, 2015 | Honeywell Ademco Vista 20p And 6150 Keypad...
Trying to change master code on 6150 vista 20
Either you are locked out of installer programming or you do not have a Vista 20...this sounds more like a larger panel such as a Vista 40, 50, or some other 4140 based system...verify the model number by opening the main cabinet. The inside cover should have a diagram of the system and the model number. However, since the boards are easily replaced, the cover label is not always accurate. Look at any labels on the printed circuit board to help you properly id the model. By the way, FC indicates Failure to Communicate, meaning the unit tried to call the monitoring center but could not get through (usually 10 attempts) and is unrelated to the "master code". Hope this helps.
Jan 31, 2015 | Honeywell Ademco Alarm Vista 20p 6150...
Remove FC code Ademco Vista 15P alarm sysem
FC means failure to communicate, call your monitoring company to test your systems communication. If your system uses or used your phone line call on a cell phone so you don't get cut off when you system tries to call to monitoring company. gl
Jun 05, 2014 | Honeywell Ademco Vista 20p And 6150 Keypad...
Security code program for ademco alarm 6150
6150 is the type of keypad you have the alarm system itself. The 6150 works on a number of different Honeywell panels. You need to locate the main metal box and open it. There should be a white sticker on the board with the panel type. (Ex. v10,v20, Vista...)
Oct 21, 2011 | Honeywell 5804 Ademco Wireless Security...
Two nights ago, there was a major power surge in my area and lots of appliances were knocked out. The alarm box AC transformer burnt out. I replaced it but the alarm system, every half hour or so keeps...
It's possible the power surge damaged the panel as well. Disconnect the battery and wait for the AC Loss. You'll get a Low Battery on the keypad. Enter your code + off to silence the beeping. If the panel is damaged, it will shut off and back on when you would normally get the AC Loss. Good Luck.
Apr 14, 2011 | Honeywell Ademco Vista 20p And 6150 Keypad...
Display showing open circuit, how do i fix this?
One of the wires that connect to the same location as the Ademco 6150 Alarm Keypad + 5881enm Wireless are damaged. locate the bad wire and repair. Error will go away. GL.
Feb 17, 2011 | Honeywell Ademco 6150 Alarm Keypad +...
I changed the system battery for my alarm but it is still showing low system battery
Run a sensor test on system. Enter your code then 5 + 0. Be aware that if you have a a siren it will go on for a second. Let test run for about 3-5 min or until it resets. GL.
Dec 31, 2010 | Honeywell Ademco Security Alarm Vista 20p...
My lcd screen is blank and system doesn't respond to commands... Says ''not ready'' but that's it! There is power to the units but no response except a single beep after the pin and command is entered. It...
FYI 6150 is keypad model not alarm model. See if yhis helps. try pressing the " * " key bottom leftit thould then indicate zone trouble or fault. that sould give you at least some place to start.
Feb 07, 2010 | Honeywell 5804 Ademco Wireless Security...
Need a security code for my Nokia 6151 imei 352743014409642
Unlock Code:
6220364114
1 - Switch on your Nokia 6150 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6150.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6150 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6150 mobile phones locked to the network Fido in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
Cheers
Jan 20, 2010 | Nokia 6151 Cellular Phone
55 people viewed this question
Top Honeywell Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Honeywell Audio Player and Recorder Expert? Answer questions, earn points and help others
