Question about HP Office Equipment & Supplies
In My Hp laserjet m1500 MFP the Toner is leaking and when I print lines are coming on paper
  • 3 Answers
SOURCE: HP laserjet 2600n
You are spilling blue toner. Try to vacuum out the excess blue toner from the machine. Be careful not to scratch the transfer belt.
Posted on Dec 13, 2007
SOURCE: hp laserjet 1000 prints horizontal lines
software download
Posted on Apr 18, 2008
SOURCE: HP Laserjet 4250 leaking Toner
time for a printer plumber no doubt...leaking toner is not a good sign..
Posted on Aug 19, 2008
  • 326 Answers
SOURCE: HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
Posted on May 06, 2009
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
Black line coming while printing on hp m5025mfp
the problem is in fuser or in toner cartidge.
print a page when the printer start to pull the paper more than a half page stop the printing by open the door
remove the toner and look the paper
if you see the line the problem is from toner replace toner cartidge if you see the image ok means the problem begins when the paper go into the fuser so replace fuser.
Feb 20, 2014 | HP LaserJet M5025 MFP Printer
HP laserjet 100 mfp blue line
I had the same kind of problem with the same printer.
The problem started with yellow toner powder 'leaking' inside the printer and contaminating the printed documents.
After inspection, the yellow cartridge showed what seamed to be like caked/cluttered powder between the magnetic roller and the doctor blade.
I dismantled the cartridge to realise the 'caked/cluttered powder' was in fact a sponge material. The internal 'spongy' toner feeder roller was damaged and little pieces of the material was coming out of the cartridge.
After further inspection inside the printer (all cartridges and drum removed), I found two little pieces of the same material stuck between the kevlar roll and the metallic housing underneath it. (going up, from bottom to top, you have the pile of paper in the feeder -> horizontal metallic plate -> kevlar roll -> toner carousel.)
I used a strip of heavy paper (200g) to gently remove the two sponges, set two clean jobs and the problem was solved.
The kevlar roll is also accessible from the printer's back door, some material may also be stuck in this location.
Nov 06, 2012 | HP LaserJet Pro 100 color MFP M175nw -...
HP Laserjet M2727nf Mfp Printer scan to e-mail first page correct but other pages come out with lines
First print a test page out from a computer. If this has lines then its either a dirty drum in the toner cartridge or a bad fuser. IF the test print is fine then you just need to clean the glass over the scanner.
Jun 11, 2012 | HP Laserjet M2727nf Multifunction Printer
WHENEVER I PRINT I GET A GREY BACKGROUND IT LOOKS LIKE DUSTY PAPER BUT IT ISNT? WHY IS THIS?
If the black toner cartridge (Q6000A) is not original, problem with the doctor blade, bad calibrated.
Use Original cartridges?
See This:
The amount of background toner shading becomes unacceptable.
1.The media might not meet HP specifications.
  • Use a different paper with a lighter basis weight.
2. Use a different paper with a lighter basis weight.
  • Check the MFP environment.
3.One or more print cartridges might below. If non-HP print cartridges are used, no messages appear on the control panel or in the HP ToolboxFX.
  • Replace any low print cartridges.
Aug 03, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Hi there, my hp laserjet M1120n MFP is printing with thick black lines? Please assist.
Hello
Unfortunately Thick black lines usually indicate a Fuser-Drum issue. These parts can become worn over extended use and should be replaced. You can try pulling the toner and drum unit out and re-installing them, but if the problem continues then a replacement drum is advised.
Regards GM
Apr 27, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
Hp m3035 won't print page comes out warm but no toner
Load paper in tray 1. Print a few pages, as it's printing open the top cover, remove the toner, look at the paper in the printer. Does it have printing on it? If it does, the laser/scanner is working. It could be the transfer roller, it could be Hi Voltage Power Supply. Look in Print Quality Menu/Toner Density. Increase the density.
Mar 10, 2010 | HP LaserJet M3035 MFP Printer
I have an HP Laserjet M1319f MFP printer, when I print it uses alot of toner. How can I program it or what can I do on the computer to use less toner?
You can set the density lighter or put the printer in economode. You may not like the print quality as it will be extremely light. But the toner will last longer.
Save toner
1.
On the File menu in the software program, click Print.
2. Select the driver, and then click Properties or Preferences.
3. On the Paper/Quality tab, click EconoMode.
4. Click OK.
Nov 05, 2009 | HP Laserjet M1319F Laser Multifunction...
Print quality problem
Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
Thanks J
Jan 14, 2008 | HP LaserJet 2420 Printer
Seeker5211
Seeker5211
