How to connect more than two rf tranciever in a mesh network
To share data between each other
Wireless connection
Turn off the laptop, unplug, remove battery, plug in. Push and hold the reset button for 30 seconds or so on the Netgear to reset to default settings. Boot laptop, when boot is complete, Open Network and Sharing Center, click on Manage Wireless networks, remove your OLD wireless network. Close Network and Sharing Center. In your Tray Notification Area , left click on the network icon, select unsecured Netgear Wireless Network. When connected, reconfigure SSID and Security Password.
Dec 16, 2012 | Acer Aspire 5742Z-4200 Notebook
I can not get my kodak hero 5.1 printer to work on my windows xp 64 bit
Turning sharing on or off
The first time you connect to a network, you'll be asked if you want to turn on sharing between PCs and connect to network devices such as printers. Your answer automatically sets the appropriate firewall and security settings for the type of network that you connected to. You can turn sharing on or off at any time.
To turn sharing on or off
  1. hh_ppeic.pngTap or click to view available networks.
  2. Press and hold or right-click the network you're connected to, then tap or click Turn sharing on or off.
    435600ef-5a98-4568-bfa2-28d51981b1e3_13.jpgMenu used to turn sharing on or off
  3. Do one of the following:
    • Choose Yes, turn on sharing and connect to devices for home or small office networks, or when you know and trust the people and devices on the network. This setting allows your PC to connect to devices on the network, such as printers.
    • Choose No, don't turn on sharing or connect to devices for networks in public places (such as coffee shops or airports), or when you don't know or trust the people and devices on the network.
      Notes
      • Turning sharing on prepares your PC for sharing files and devices on a network. For more information about sharing with other people on your network, see Sharing files and folders on a network or a shared PC.
      • The network sharing setting is only available for WiFi, Ethernet, VPN (non-domain) and dial-up (non-domain) connections. It's unavailable for domain networks. On VPN or dial-up connections, you must connect to the network first, then press and hold or right-click the network name to change the network sharing setting.
      • Turning on sharing changes your firewall settings to allow some communication, which can be a security risk. If you know you won't need to share files or printers, the safest choice is No, don't share or connect to devices.
      • Choosing No, don't turn on sharing or connect to devices blocks the following applications and services from working: PlayTo, file sharing, network discovery and automatic setup of network devices.
About network discovery
Network discovery is a setting that affects whether your computer can see (find) other computers and devices on the network and whether other computers on the network can see your computer. It's one of several settings that are turned on when you turn on network sharing. You can turn network discovery on or off independently of network sharing, but we discourage this. Here's why. If you're connected to a network in a public location and you decide to turn on network discovery but leave network sharing turned off, the network discovery setting will be on for every public network you connect to from then on. This wouldn't be safe. That's why we recommend using the network sharing setting instead.
However, if for some reason you need to turn network discovery on or off independently of the network sharing setting, here's how to do it:
  1. hh_ppeic.pngTap or click to open Advanced sharing settings.
  2. Tap or click the chevron 7d2e0f87-bcfb-44a3-8422-5c9353bcde11_89.jpg to expand your current network profile.
  3. Tap or click Turn on network discovery or Turn off network discovery, then click Save changes. 1f9463c2-c968-47bf-9b4d-939c5d1af477_70.jpg You might be asked for an admin password or to confirm your choice.
Jan 07, 2012 | Kodak Office Equipment & Supplies
Nokia 2690 cannot connect to the pc
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
Subject: How connect a Nokia 2626 to a computer
This is done in two ways: 1. Bluetooth adapter; and, 2. Data Link
If your computer is incapable of receiving Bluetooth, hou'll have to buy an adapter.
To use a direct connection, I recommend LiveMesh.
From the publsher:
Your work computer, home laptop, Mac, or mobile phone- devices live in multiple places. But the files you need--and the programs that open them--often don't. Live Mesh changes all that. With Live Mesh, you can synchronize files with all of your devices, so you always have the latest versions handy. Access your files from any device or from the web, easily share them with others, and get notified whenever someone changes a file. Use Live Mesh to connect to your other computer and access its desktop as if you were sitting right in front of it. To download for free Clck Here
All the best,
Ben
Sep 23, 2011 | Nokia 2626 Mobile Phone
How can I connect samsung gt-i5801 with my Laptop for Internet usage
What you need is USB tethering.
USB tethering
You can set your device as a wireless modem for PCs and share your device's mobile network connection via USB.
1 Using an optional PC data cable, connect the multifunction jack on your device to a PC.
2 In Idle mode, open the application list and select
Settings ? Wireless and network ? Tethering.
3 Select USB tethering to activate the USB tethering feature.
Your device will share the mobile network connection on your PC.
To stop sharing the network connection, clear the check box next to USB tethering.
The sharing method for the network connection.
The manual is here
http://downloadcenter.samsung.com/content/UM/201106/20110614142414209/GT-I5801_UM_SEA_Froyo_Eng_Rev.1.1_110601_Screen.pdf
Nov 13, 2010 | Samsung Computers & Internet
RF gun is not getting a valid IP address from a
Check to port assignment in the guns. Sounds like a encryption issue. Did you go through the connection procedure like you do with a PC? Port, passcode, etc?
Feb 09, 2018 | Symbol PDT6842-NIS632EU Portable Data...
How do I do file transfers from one wireless laptop on a westell 6100 dsl model to another wireless laptop on the same modem. Neither laptop in connected to the modem via eithernet. how would I set this...
Hi There.. Please follow te below steps..
1) Connect your old computer to the wireless network. Nowadays most people use the internet through a wireless network. So basically, if you have wireless internet and you are able to get on the internet... that means you are connected.
2) Go into the networks settings. This is usually as simple as right clicking the network's icon and then clicking properties. What you want to do is turn on, "file and printer sharing" within the network
3) Now, go to the folders/data that you want to transfer. Right click or get into the properties of that folder. Check the box that says "share this folder with network".
4) On the new computer, connect to the wireless network. Under control panel or possibly the start menu, there should be an option for "My Network Places" or "My Network". In this folder you should find the data that you chose to share from your old computer. You can simply copy/paste or drag/drop the files to your new computer.
Now you are offset to transfer the files from one laptop to another...
Was this information is helpful. Kindly revert if this helpful..
Jan 12, 2010 | Westell Wirespeed LiteLine 6110 Modem
My lg phone says im roaming when im not and it wont let me send out text's or recieve
Your phone is programmed with parameters to trancieve from a particular network. It roams when you're outside the coverage area or when the programming parameters have been altered in some way. Check your settings or refer to the network's programming unit to have the parameters entered correctly... then you'll be connected to the network services.
May 04, 2009 | LG ALLTEL AX275 Cellular Phone
I need to control the peer to peer network clients?
hi
you can use a proxy software, to limit the bandwidth usage, if that is what you meant. a very simple and user friendly proxy software is CCPROXY.
kind regards
Mar 11, 2009 | Southwestern Bell (S60802)
How to install the lexmark E120 network printer
to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
Dec 22, 2008 | Lexmark E120n Laser Printer
Got connected, but no recieved data
Firstly don't encrypt your connection until it is up and running. Depending on your router, if you require it to allocate IP addresses automatically you have to make sure enable DHCP is ticked, otherwise see what the IP address of the router is e.g 192.168.2.1 and set your network TCP/IP properties to 192.168.2.2 or any last digit as long as it is not the same. This is the router IP address and not your ISP address. Lastly set up your encryption but there are two ways of sharing the connection, one is called a 'wep shared key'; the other 'wep open' so make sur your pc wireless network is sharing the same type of WEP. Hope this helps Please rate this solution.
Nov 08, 2006 | NetGear MA101 802.11b Wireless Adapter
Computers & Internet Logo
David Payne
David Payne
