We have AMS 21 OD we found error code 104 - Washing Machines
Error code 104 on velocity is popping up when trying to stream TV shows. How do I fix this issue?
error 104 means the Url or M3u Playlist has changed or...far too many people are using the same stream and exhausted the connection
this happens on Kodi and IPTV apps all the time,
internet Tv Urls usually have to keep getting updated once people start sharing the playlists, if you are using IPTV or KODI apps, to view other country channels being streamed, my guess is too many people have found it out, may want to get a new updated stream url list.
however if this code is from you watching a live stream on youtube or a subscription service like foxtel or Really UK then your internet connection cannot buffer quick enough.
Apr 26, 2017 | Televison & Video
Hi We have JUKI AMS-210D and facing problem in no display. Error code 100, 101, 104 comes we check cable J14 fuse every thing. Anyone can help.
Have you researched what the codes signify? That will give you a good clue of what's going wrong and how to address each. In your case, since you are having multiple issues, service may be a good option.
According to this link, it means a board problem:
How to solve error 100 in JUKI LK 1930 bartacking machine some time will...
Dec 17, 2016 | Juki Sewing Machines
Hi fri, I have juki AMS-210B .I NEED AMS210B ERROR CODE.I DON'T KNOW ERROR NO.1
If the Error Code is not in the owner's manual, might be best to contact Juki Support.
Jan 20, 2016 | Juki Sewing Machines
Fix code 104
104. (01101000) See Fault Code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jan 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
AMS PANNEL CONNECTION ERROR
h there
please check connector J14 at main board if problem still i think need to chane panel or main board
best regards
aabozid@hotmail.com
Mar 30, 2010 | Juki Sewing Machines
What does error code DRMClien.DLL mean?
This might help: http://pcsupport.about.com/od/findbyerrormessage/a/drmclien-dll-not-found-missing-error.htm
It includes, several possible ways the error might happen and ways to counteract and fix the problem. Hope this helps :)
Oct 19, 2009 | Video Game Consoles & Games
Od code
od code is supposed to mean that lid has not been opened for the last 3 completed cycles. Also, apparently you tried the service mode and found the door lock to be working. So, unless the problem is with the electronic board itself the only other thing that could be happening is a faulty sensing switch at the door lid or a bad connection to it. I would try shorting the leads from the switch and see if the problem goes away. Then you might just need a new switch.
Feb 15, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
