Question about Comfort Zone Heating & Cooling
Comfort zone quartz infrared heater used for first time cut off & now the only button that works is timer, power button lights up & 2 green lines in the screen. Please help before I freeze!!
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Posted on Oct 14, 2008
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Posted on Dec 06, 2008
micromatikal
  • 2777 Answers
SOURCE: I have an AO5 error
This indicates a power fault inside the actual heater. Have you tried unplugging the heater, letting it sit for a good 2 minutes, and replugging it back in? If the problem persists you will unfortunately need a repair. Please let me know if you need more information on this. You can also contact comfort zone, the manufacturer, located in Canada, at 780-420-6572.
Thanks so much for the question,
Tim
Posted on Sep 09, 2010
  • 4736 Answers
SOURCE: I have a comfort zone
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Posted on Jan 20, 2011
  • 123 Answers
SOURCE: I have a comfort zone infrared heater and the
This sounds like a thermo coupling/ flame sensor. Check this and ensure that it is working properly. Also you can use an air compressor to blow out the infrared plates to ensure that it does not have dust build up in it. That can cause you problems as well.
Posted on Jan 27, 2011
I have a quartz infrared zone heater and I need to know how to reset from celsius to regular heat
There you go
OPERATION INSTRUCTIONS
FUNCTION
POWER
The POWER button supplies power to all the functions of
the heater. Pressing the POWER button again the heater will
be put in standby mode.
Pressing and holding the POWER button on the control
panel for 3 seconds will switch between °F and °C.
Dec 25, 2017 | Heating & Cooling
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Comfort Zone Infrared Quartz Heater is not staying on it cut right off. Please advise
Clean the filter and the element. Make sure that they are dry before you re-install them. Check the power cord and socket for damage..
Feb 21, 2015 | Comfort Zone Heating & Cooling
Comfort zone heater
If its to close to the wall it can shut off due to high temp
Feb 25, 2014 | Heating & Cooling
Heat but no fan
Temperature fan switch needs replacing...make sure there is power to it.
Dec 17, 2013 | Comfort Zone Infrared Quartz Heater
I have a Comfort Zone cz20110 and I need help. The heater will turn on and blow out heat, but the display screen is blank. It was not blank when we first plugged it in however and I know there's a way...
i have a digital quartz infrared heater comfort zone cz20110. does the fan keep running all the time and when it reaches the temp to your room why doesn't it it shut off.
Jan 02, 2013 | Heating & Cooling
My Cz2011 Comfort Zone Infrared heater will not stay on. It will stay on for maybe one minute and then it shuts off
I had same problem with mine and found out that the timer was turned on make sure your timer time is set to 00 hope this helps
Jan 01, 2013 | Comfort Zone Infrared Quartz Heater
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Jan 18, 2011 | Comfort Zone Heating & Cooling
How do you change from celcius to farieheit on comfort zone heater
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
Nov 28, 2009 | RTO Comfort Zone Electric Portable Space...
Heating & Cooling Logo
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
