Question about Lands Phones
How do I transfer a call to the phone that is connected to the parallel port of the KX DT343? What is the extension number for that phone?
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
  • 208 Answers
SOURCE: USB to Parallel connection (Panasonic KX-P1121)
I assume you installed the driver that came with the cable. The driver should create a new printer port like lpt1. That's the port you should use in the printer configuration.
Posted on Sep 02, 2009
  • 113 Answers
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
Posted on Mar 23, 2010
  • 2460 Answers
SOURCE: I have followed the instructions
Did you use the *7102/3/4/5 code? There is forward inside, outside, or both. The *710x forwards both.
Posted on Nov 17, 2010
  • 2460 Answers
SOURCE: how do i change the
From the phone connected to extension 101, press PROG and dial **1234 If the display responds Sys Prog #, then dial 004 and enter. It's the menu to assign names to extensions. You can sort of follow along and use the arrows, the keypad, and the ENTER and SAVE buttons to step through the names and change them.
Posted on Aug 26, 2011
How can i create extension line on a panasonic KX-DT343 console
Try Googling (Panasonic)(KX-DT343)(manual) without parens for instructions.
Jun 23, 2017 | Panasonic Lands Phones
How do I transfer a call so that it goes directly to voicemail without the phone ringing? I have the Panasonic KX-DT343
Can you not download the KX-DT343 owners manual as a PDF and maybe you might find what you are looking for there not sure.
Feb 20, 2015 | Panasonic KX DT343-B Digital phone - Black
KX TA308 how to disable 2 locals Ring sametime
There are two possibilities, you have to check to confirm. Either the two were physically wired in parallel or through programming they were configured to ring simultaneously. Start by checking if the two were physically wired in parallel. One way would be to establish how many extensions you have altogether and is it equal or less than the total number of extension ports available on the KX-TA308?
Apr 03, 2014 | Panasonic KX-TA308 Phone
How to change recording on day/ night mode
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode SVM day *47 (voicemail extension number) (PIN number) *38801 record STORE NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
Aug 12, 2013 | Panasonic BTS KX-DT343-W-NR Digital Corded...
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
We have a KX-DT343 at the office. How can we transfer an outside call directly to another extensions voicemail if we know the person is not at their desk? The phone does not have a VT button.
I recommend you to read your inst. manual. they contain a LOT of information by you can take action in according with your request.
God bless you
Oct 03, 2012 | Panasonic KXDT343 Phone
I dont know how to assign Incoming call log on Panasonic phones
Calls log auotmatically to phones that ring. If more than one phone rings the call will log on the phone that answers. If no phone answers, the phone connected to the lowest port number will log the call. The lowest port number is usually the lowest extension number, but not always depending on how the phone system installer numbered and connected the extensions. Also if a call is transferred to a phone it will log. The logged calls can be seen by navigating the LCD screen.
Dec 11, 2010 | Panasonic KX-T7731 Corded Phone
When I try to hook a second kx-t7630 to another (parallel) I can make outgoing calls but cannot answer them.
I'm guessing you're using the Digital XDP port. Each of the phones has an extension and that 2nd extension number has to be added to the ICD group as a phone for the lines to blink or ring on the 2nd phone.
It requires system programming.
Sep 24, 2009 | Panasonic KX-T7630 Corded Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
