Question about Kenmore Microwave Ovens
How to replace the main fuse on my Kenmore microwave
2 Suggested Answers
  • 35 Answers
SOURCE: fuse blew microwave
Sounds like a fault on the magetron power supply.
If you are confident enough to ground and discharge the main capacitor, check to see if it is faulty.
Check for arcing or scorch marks around the transformer and check the HV lines on the magnatron input for continuity.
If the capacitor has blown out, this can be replaced, however if the magetron or transformer is faulty this is a much more complicated repair and should only be done professionally.
Posted on Mar 25, 2010
Testimonial: "Thanks for such a timely response."
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
I have a Kenmore Microwave Hood 721.63653300. I unscrewed one of the light bulbs and the glassw seperated from the base which cased a small pop now the unit will not run. I have check the power to the unit...
All Microwave ovens have a main fuse that is not accessible while the unit is mounted under a cabinet. Drop MW oven and replace the main fuse.
Dec 23, 2017 | Microwave Ovens
How to change the fuse in a kennmore microwave
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 27, 2011 | Kenmore Microwave Ovens
Okay you said it was probably a fuse so where is the fuse located?
Hope this helps.
Feb 19, 2011 | Kenmore 63792 Microwave Oven
I have a 20-yr-old microwave--a kenmore 565.8824581--that just suddenly stopped working. no lights, nothing. offhand do you think this might be a fuse issue that is fixable, or would this simply warrant...
Hope this helps.
Jan 21, 2011 | Microwave Ovens
Microwave won't start
Hope this helps.
Dec 29, 2010 | Kenmore Microwave Ovens
Fuse blew microwave
Mar 22, 2010 | Microwave Ovens
Kenmore Spacemaker Fuse Blown
its either a 10-15-or20 ceramic fuse and its marked on the side of the fuse or take it to the hardware store they have this type of special fuse.and they can locate the rating for you
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except it doesn't heat anything
no, just 1 main fuse for everything. there are temp safety devices though, and door closed safety switches. Most likely failure though is the magnatron.
Dec 30, 2007 | Kenmore 64002 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
