Question about Daewoo Refrigerators
Daewoo American fridge freezer fridge not getting cold
Optical sensor been covered accidentally for few weeks now fridge not cold.is this repairable
    Top Expert:
  • Daewoo Master
  • 50,533 Answers
Cal a technician for a diagnosis of the fault then decide if it is repairable
Posted on Dec 10, 2016
My daewoo fridge freezer is freezing food I the fridge on every shelf
Turn down the cold control there can be 1 or 2 if 2 one is main electronic the other just a baffle that controls how much cold air in freezer is allowed into fridge that is be pushed by the fan located in freezer. Cold is only made in freezer then does a circular tour as it leaves cold in freezer moves top 2 bottom then as its warmed it enters freezer to do it all over again . Adjust baffle and or control in this unit it may show 0 or off but there seems to be a lot of movement available before it does turn fridge off. Ive had on a few occasions had how the shelf's are arranged deflect the or mess with the cold airs intended route.
Mar 16, 2017 | Daewoo Refrigerators
Daewoo Side by Side American Fridge/Freezer
It sounds like there can only be 2 causes for the failure.
  1. The compressor is running inefficiently (normally caused by blow by or a bad winding on the compressor) - The only way to know of this is to hook a set of gauges up to the system to see the High and Low side pressures, and to check the resistance of the Run, Start, and Common windings of the compressor.
  2. There is a leak in the system (Normally very hard to find in fridges) The only way to know this is to hook up a set of gauges to the system. In order to find a leak in a fridge i would use an electronic leak tester as it can get into very confined spaces. The other way to find a leak would be to pressurize the system with nitrogen, and try to hear for leaks. If there is a very small leak you will have to go around with soap and water, or a type of refrigerant leak detector. The unit is more likely to leak on the high side of the system due to higher pressures and tempratures. This would be from the discharge of the compressor to the metering device, or the inlet of the evaporator. Other common places or leaks would be, the evaporator coil, or the condensing coil, along with any joints there may be in the system.
If the system just suffered a leak, and there is no damage to the compressor. If the leak is easily identified and repaired, the system can be recharged and repaired for a few hundred dollars. However this is normally not the case with leaks. If there is a small leak it can take hours to find and repair. Also if the leak is in the condenser or the evaporator, a replacement and the cost to replace it would normally cost about the price as a new fridge. The same goes for a compressor issue. If the compressor is running inefficiently, and must be replaces, the cost of the replacement compressor, the labor to replace it, and the refrigerant to recharge the system would also normally cost more then the price of a new fridge.
If you are going to have it repaired, have it done by an Appliance Repair Technician or a Refrigeration Technician.
Having said all that, have it done by an Appliance Repair Technician or a Refrigeration Technician or Buy a new Fridge Freezer.
Sorry I couldn't be of more help.
David
Feb 22, 2018 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
Daewoo american fridge freezer bad smell
look up the fridge on line or check the manual how the freezer is build. some freezers have a small space under the bottom of what you see as the bottom, where liquids can be trapped and haunt you for ever if you done lift the bottom part up and get under it. good luck
Jan 27, 2018 | Daewoo Refrigerators
Daewoo FDF-358 fridge is taking a couple freezer is taking a couple of days to freeze solid and the fridge is just not keeping anything cold ..... fan in the freezer is not iced over, there is no feel of...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Daewoo Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | Daewoo Refrigerators
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Refrigerators Logo
47 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
