Question about Whirlpool Microwave Ovens
How can one dry rusks in a Whirlpool jet chef - microwave oven ?
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
  • 72 Answers
SOURCE: magic chef microwave which also has oven model
magnetron or door switch issue
Posted on Feb 04, 2010
  • 8909 Answers
SOURCE: My Sharp Quartz Chef Jet
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 07, 2011
  • 2113 Answers
SOURCE: magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Posted on Nov 30, 2013
  • 77932 Answers
SOURCE: My monogram jet microwave convention oven will work with oven but microwave won't work.
Then the Microwave is most likely defective, time for a new one is my suggestion.
Posted on Jul 13, 2016
Picture of symbols on Whirlpool Jet Chef 369
We need a little more information on the microwave you are referring to. We need the actual model number from the microwave, the Jet Chef 369 is not enough to go on.
Jul 23, 2015 | Whirlpool Microwave Ovens
Clicking noise when going
Sounds like a high voltage arcing. possible transformer or insulation failure causing an overload. Not a recommended consumer fix.
Feb 28, 2015 | Whirlpool Jet Chef 31 Litre 1000 Watt...
Magic chef microwave lamp replacement model mcm1110b
Nov 29, 2013 | Magic Chef 1-1 Cu Ft Microwave Oven -...
Magic chef 990W microwave clock keeps resetting. What is wrong and how can I fix?
Make sure that the program controller is receiving power - step down supply. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link:
Since the clock is resetting it is a fault on the main board and the processor as it is tripping. So check power, check for faults mentioned above on the board. Also if there is fault of the magnettron leak or a waveguide leak then clean and check insulation.
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link:
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Sep 23, 2011 | Magic Chef MCD990W Microwave Oven
Need Manual for Whirlpool Jet Chef 1000watt Microwave Model JT369/sl
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 15, 2011 | Whirlpool Microwave Ovens
Where is the fuse located
We have here below the link with the parts layout of your microwave
oven model. The fuse is part no 15 Line fuse
Part Number: AP3119665
Which as you can see is
located in the internal control parts area.
Dec 19, 2010 | Magic Chef CMV1000B Microwave Oven
Magic Chef Microwave runs but no heat produced,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
May 11, 2010 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
