Question about Home
My mansfield 160 toilet tank will not fill after flush. I will turn the water off and then on and it will fill and then after it is flushed it will not fill.
    Top Expert:
  • Home Master
  • 51,255 Answers
Indicates a problem rubber washer on the inlet valve
get in a plumber or get replacement rubbers form a quality hardware shop or plumber supplies
rubbers expand with age and jam over the small opening
Posted on Dec 10, 2016
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Running toilet.
Bad float valve or water leaking by the flapper or whatever the handle is connected to that initiates the flush...
Mar 11, 2014 | Mansfield Summit 3 Tank Only 386-WHT -...
Mansfield 160 toilet diagram
The tank bolts do not get removed. The flush valve is mounted in a hole toward the rear of the tank. The nut under the tank is removed to allow removal of the flush valve from the inside of the tank. The replacement flush valve is inserted into the hole inside the tank and the nut is installed to fasten it in place
May 15, 2013 | Danco Flush Valve. Replacement Flush Valve...
Toilet is not flushing
sounds like you need to adjust water level in tank,take lid off and check if theres enough water to flush should be a water level line in tank.
Sep 24, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
My Mansfield toilet flushes but only 1/3 of the water in the tank flows out during a flush and the bowl does not get enough water to flush everything.
Check the water level int he tank for it coming up to fill line in tank. Make sure the 1/4 " fill line from the fill valve is connected and in the stand pipe tube to allow water to fill bowl. Fluid master makes a flapper that has adjustments on it to increase or decrease water used to flush. It has a dial to move on it this would be another option if the above tried doesn't help.
Thansk and I hope this will help you with this problem.
Mar 26, 2011 | Mansfield Plumbing Products Home
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
there is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Mar 14, 2011 | Summit Appliances Division Mansfield 386...
When flushing the toilet, there is not a lot of "push" behind the flush. I'm having to flush two times, regardless of what is in the toilet.
It is normal for these useless new tanks to do that. Won't even flush a piece of paper. Pull off the lid and make sure the little hose is in the overflow pipe, and raise the water level as high as you can. take out all the bricks and water bottles, and bowl cleaners. Then give it a try. It might do a bit better. Hope this helps.
Jul 03, 2010 | Mansfield Plumbing Products Mansfield...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
Mansfield 160 extremely difficult to make it flush
If this is the model am thinking it is, you need to replace the flapper. it goes down in open to far and gets bound.Or if you have hard water or calciaum buildup,it is making for a tighter opening. I hope this helps. :)
Jul 06, 2009 | Mansfield Plumbing Products Mansfield...
Home Logo
106 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
