Question about DIGITECH Music
DIGITECH DC-1026 INSTRUCTION MANUAL - DIGITECH Music
How can I get instruction manual for digitech xc0430 weather guage ?
Hello!
Please kindly check - here is the list of Digitech devices. Hope you can get here the one you need or a similar one.
https://manualsbrain.com/en/brands/digitech/popular_categories
Oct 20, 2017 | DIGITECH Music
Instruction manual for Digitech QM 1324
Hello
Try these links.
www.homeimprovementpages.com.au/.../jaycar_electronics_-_silicon...
http://www.dataentryjobs.us/67948.html
www.stereo.net.au/forums/.../38828-help-with-measuring-inductorsCached
ftp://ftp.digitech.com/pub/PDFs/Manuals/Vocalist_LIVE2/VL2Manual_v1.pdf
Copy and paste these links to the address bar to your borwser and press 'Enter', if you can't diretly go to ths links.
Feb 27, 2012 | Music
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
My digitech looper phrase sampler will not turn on
A common problem is that somebody has paired the WRONG power adapter to this unit.
The REQUIRED adapter should be 9VAC (not DC) at 1300ma or 1.3 amps.
Note that UNIVERSAL replacement adapters will NOT work with the Vocalist.
Feb 06, 2011 | Digi-Tech Digitech Vocalist Live 4...
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
35 people viewed this question
Top DIGITECH Music Experts
Michial Gueffroy
rhodesworks
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
