Question about RCA Video Cameras
I accidentally reversed the polarity on rca camcorder.Now it only will stay on 5_10 min.over and over .I think something's heating up and kicking it of .Fixable? Thanks
5 Suggested Answers
  • 597 Answers
SOURCE: Accidental reversed polarity with an external hard drive
You can send it so some of the data recovery people and they can usually get the data off. It's rather expensive but in your case it should be do-able.
http://support.wdc.com/recovery/index.asp?lang=en&selregion=americas
this link has several data recovery services that are all pretty good.
Posted on Oct 01, 2009
Adrian762
  • 425 Answers
SOURCE: Accidentally wiring the battery in reverse has killed electrics!
When you do such things, you generally blow what is called a fuse link. I can't find a manual to suit your machine. Follow the positive wire from the battery, you should come across what looks like a couple of little boxes with a piece of wire in the middle. This is the link. It is put into machines to prevent major damage if you happen to make a mistake. If you cannot find this, then it is an auto electrician job.
Posted on Jan 05, 2010
eagle338
  • 4889 Answers
SOURCE: Printer was accidentally plugged into
There will only be very little damage as most electronic devices have protection against reverse polarity. If any thing you may have to replace the component protecting the circuit(usually a diode). However this is a board level repair and is not user servicable. If the printer does not start, please contact Xerox support and they will fix it for you. Dont worry there wont be any major damage and the repair cost should be well under 100$.
Sai.
Posted on Jan 15, 2010
  • 16 Answers
SOURCE: Reverse Polarity Code
check the green ground wire, make sure it is connected
Posted on Mar 12, 2013
I hooked up the power on my corba 29 ltd by and I think I blew something inside. Is this an easy fix?
The Cobra 29, like most CB radios, contains a reverse-polarity diode whose purpose it is to protect the radio against accidental reverse-polarity hookups. Normally all you will need to do is replace the fuse, then hook the radio up correctly.
If that doesn't get you going, then possibly the polarity-protection diode is now shorted and will have to be replaced (or removed - not recommended).
Beyond that, my experience is that the next component most like to get damaged is the Audio Output circuit, either an IC or a power transistor (larger than a regular transistor). At this point you're going to have to take it to a repair shop.
Aug 04, 2014 | Radio Communications
Would like a circuit diagram for dell inspiron 1000 power circuit
There is a reverse polarity diode that prob popped. It doesn't allow the power to even reach the battery anymore. It'll prob charge in another laptop that takes that battery. The diode is on the mother board.
Nov 24, 2013 | Dell Inspiron 1000 Notebook
Mar 12, 2013 | Heating & Cooling
Honda eu10i reverses polarity on boat
Polarity lights in AC means that it thinks the wrong input lead is earthed ie neutral.
If polarity detector is showing that there is no neutral earth bond it may not be a bug but a feature, as standard the EU10i would not have an earth neutral bond.
Otherwise I can not see why your detector thinks there is a polarity reversal.
Kevin H
Jan 24, 2013 | Honda Eu-1000i Inverter Generator
Canon GL1 won't power up
Typically, fuses protect the "hot" side of circuits. The reverse polarity puts the ground plane on all the power feeds in the circuit, and the normal ground plane becomes hot with unregulated voltage, which will fry anything not rated for the full supply, and it will do it before the fuse blows. There are often fusible links in small voltage circuits such as camcorders, and they're basically low ohm resisters that open up when overloaded, and act as fuses. You have to really know circuitry to spot them, or have a schematic. If you can get a used camera with a lens problem on ebay, you could probably swap out the circuit boards and get it to work, otherwise, the dreaded repair guy might have to be engaged. I've rarely seen a camera revived after having this happen to it. Sorry, wish I had better news, and good luck.
Mar 27, 2010 | Canon GL1 Mini DV Digital Camcorder
Printer was accidentally plugged into a reversed polarity outlet. Will damage result??
I don't think any harm would be done because it can only be plugged in a certain way anyway, and even if you did manage to put the plug in incorrectly, it wouldn't be supplied power. I don't see it being malfunctioned by this.
Jan 15, 2010 | Xerox Phaser 7760DX Laser Printer
Jan 05, 2010 | 2007 kawasaki Z750
if the board is fried, you can take the platters (discs) out and put in another HD of same make and model to recover data. Will require special tools and patience. Its the only way I know to recover data from a blown HD. PS, use vinyl gloves as to not leave finger prints. and do this in the cleanest area you can find! Im not sure how you managed to reverse the polarity... hope this helps...
Oct 01, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Video Cameras Logo
82 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
