Question about Radio Communications
My 2011 Hyundai Santa Fe bluetooth is not working and I can't even get into the phone menu. When I press the phone button, it flashed "Initializing Bluetooth Handsfree" across the top.
  • 18 Answers
SOURCE: bluetooth handsfree connectivity
Bluetooth handsfree profiles are needed by N 72 which is missing by default in N 72 you will have to install bluetooth profiles. Please refer to nokia website for details on how to install bluetooth profiles
Posted on Mar 08, 2008
  • 3 Answers
SOURCE: pairing my bluetoth to my blackberry curve phone
When it is turned off, hold the main button in for 4 seconds until the light flashes red, the release. It should flash red and blue. This means it is in pairing mode.
Posted on Aug 28, 2008
short shadey
  • 421 Answers
SOURCE: 2005 Hyundai Santa Fe ...cruize
be sure the brake lights are working this may be a problem with the brake light switch, also be sure to check all fuses in car and under hood please rate -jeff
Posted on Sep 13, 2008
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or
I hope this helps.
Posted on Dec 19, 2008
  • 23 Answers
SOURCE: samsung bluetooth handsfree password
Posted on Jan 28, 2009
2008 santa fe 6CD Changer hows msg Initializing CD will not load or eject what to do?
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Mar 09, 2018 | Cars & Trucks
Have a 2011 Hyundia Santa Fe, the front map lights no longer come on when the doors are open. The two lights turn on with both "on" buttons. Can and how do you replace just the "door" button?
The bulb/bulbs are dead. Figure out how to get to the bulb. Extract it and take it to the store so you can buy the correct replacement bulb.
Jul 29, 2014 | 2011 Hyundai Santa Fe
How to replace starter on 2011 hyundai santa fe
To Replace the starter motor of the 2011 Santa fe is simple on nearly every make and model of passenger vehicle. The battery is disconnected to prevent electrical shock or damage to sensitive electronic components, and then the starter motor is disconnected from all electrical connectors. Once disconnected, the starter, and any shims used, are removed from the vehicle with only a couple of bolts, and replaced in the opposite order of operations. The electrical connections must be placed on the correct terminals, also known as "posts", and the replacement starter should have the same number of posts as the original.
Or you can check this video out which will guide you to Replace starter for 2010 Hyundai Santa Fe, have a look
Jun 25, 2014 | 2004 Hyundai Santa Fe
How to program key fob for 2011 hyundai santa fe
Nonsense. I just programmed a new remote start fob on my 2011 Santa Fee limited and it worked just great. Follow the steps below and see what happens.
1. Open the drivers side door
2. Turn the Vehicle ignition to the ON position (Do not start the vehicle)
3. Locate the disarm/program button. (look closely, it is located on the wiring harness just inside the lower dash. it could be located just inside the fuse cover.)
4. Press and hold the disarm/programming button for 10 to 15 sewconds, the horm will beep 3 times. Release the disarm/programming button.
5. On the fob, press the Find/Panic button One time and the horn will beep one time.
6. Turn off vehicle ignition. (YOUR DONE)
Jun 08, 2012 | 2011 Hyundai Santa Fe
Need to program key fob for santa fe 2011
you have to take it to the dealer and get it programmed with there computer. there is no other way to do so. sorry
Hyundai santa fe key fob 1 works 1 does not have changed battery deal says to buy new ,can i unlock with key without alarm going off
System operation
Pressing remote control lock button locks vehicle and activates system Fig. 1 . Indicators flash once. Pressing remote control unlock button unlocks vehicle and deactivates system Fig. 1 . Indicators flash twice.
Fig. 1
System malfunction. Remote control added or replaced.
Access alarm system control module located under driver's side lower fascia Fig. 2 . Set memory switch to SET position. Press remote control lock or unlock button. Set memory switch to OFF position. Confirm synchronization has been successful by locking and unlocking vehicle. Repeat procedure for second remote control. Synchronization can also be carried out using diagnostic equipment.
NOTE: A maximum of 2 remote controls can be programmed. NOTE: If remote control fails, system can be deactivated as detailed in the owner's handbook.
Jul 30, 2010 | 2003 Hyundai Santa Fe
Radio Communications Logo
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
