Grand faire model wcn3302gkr4 won't heat in 20 degree temperature.
  • Heating & Co... Master
  • 1,656 Answers
Is this a heat pump or gas?
Posted on Dec 10, 2016
2000 grand prix, temperature won go from ac to heat, stuck on ac.
Pontiac Grand Prix Climate Control/AC - Car Forums at > Pontiac > Pontiac Grand Prix
Dec 29, 2007 - 30 posts - ‎20 authors Hi Joe, I had the same problem with no heat on my 2000 grand prix. .... motor and the exterior temperature sensor have both been replaced ... Pontiac Grand Prix Electrical/Lighting
Aug 3, 2009
Pontiac Grand Prix Heater blower relay switch
May 13, 2009
Pontiac Grand Prix Starting / Stalling Issues
Feb 9, 2008
More results from
Fixing AC Temperature Control on my 2002 Pontiac Grand ...
? 9:58
Jul 13, 2014 - Uploaded by Turbo231
Fixing AC Temperature Control on my 2002 Pontiac Grand Prix... How To Install Replace AC Heater ...
Oct 15, 2015 | 2000 Pontiac Grand Prix SE
Heat pump not keeping up to set temperature on thermostat but never drops below 63 degrees whens its 20 degrees outside.
It may be getting low on refrigerant due to a small leak. I'd have it serviced soon. When running at less than peak efficiency it will much more often switch on the heat strips and they are not cheap to operate.
Jan 06, 2015 | Heating & Cooling
Raypak model 130a only heats water to 90 degrees
Check the temperature sensor for resistance (ohms).
(deg. F) 61 68 70 77 86 88 95 104 106
(k ohms) 14.92 12.49 11.88 10.00 8.06 7.69 6.53 5.33 5.10
If your ohms are below about 7K the heater thinks the water is hotter than it actually is, so it shuts down. It's a fairly common repair.
Jan 10, 2014 | Pool & Spa
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Feb 08, 2010 | Weber Genesis Silver C Grill
I have a 25,000 BTU hanging furnace, will this heat a 900sq foot garage that has been insulated.
Here in Vermont we design heating systems to perform at -10 to -20 degrees. Depending upon how tight the doors and windows are, it may if your temperatures don't drop below 20 degrees. It may take a while to heat up and I would not expect any temperature over 62 degrees inside the garage. Maybe a 50,000 Btu heater? Remember the output may be 20% less than the rated input of the heater.
Dec 29, 2009 | Dayton Gas Furnace Heater
2000 Pontiac Grand AM little heat being produced.
1st thing to do is change the thermostat. It is either missing, or stuck open (you provide good info). This is why the car is not running at operating temp and why you have little heat. The no blower for settings 1-4 probably means a bad switch.
Dec 17, 2009 | Pontiac Grand Am Cars & Trucks
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
