Trying to install Honeywell RTH7560E. Current wiring doesn't match. How can I find out if I can install this new thermostat?
SOURCE: changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Posted on Feb 16, 2008
SOURCE: Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Posted on Nov 25, 2008
meBNme
  • 334 Answers
SOURCE: Old thermostat wiring doesnt match up with new thermostat
Look at the instuction booklet (or on the T-stat board) for a switch for the reversing valve.
Some systems reversing valves are in cooling mode when energised, some are in cooling mode when NOT energised.
You are looking for the switch (Usually very tiny, or a different jumper setting) that will change the position of the reversing valve when calling for heat/AC.
This is not a switch like the typical "ON OFF AUTO, HEAT COOL EMG HT switches. It will be on the board itself or the back of the T-stat.
Posted on Dec 06, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 306 Answers
SOURCE: I'm installing a Honeywell RTH7600B
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Posted on Jan 16, 2009
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
Wiring with Honeywell RTH6400
I have the same problem. I am Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall. Do I have the wrong thermostat. The manual doesn't explain this siutation.
Thanks!
Dec 29, 2009 | Honeywell FF12HH Thermostat
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Honeywell RTH230B
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Im changing an old honeywell thermostat with a new honeywell thermostat. the old on has wires 4 wires connected to 4 screws C,R,G,W but the new thermostat has a place where the wires go which are...
Yes, I believe that you will be fine. If the original wiring is correct then I have listed the basic wiring below. As always read the directions and make sure the wiring matches your system.
Red wire = Rh (24v power, should have an exsisting jumper to RC)
White wire = W (heat mode)
Yellow (or sometimes blue) wire = Y (A/C)
Green wire = G (Indoor Fan)
Jul 03, 2008 | Honeywell Heating & Cooling
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
780 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
