Question about Kyocera Cell Phones
Can I retrieve info that has been deleted from the notepad in the tools section on my kyocera duraxv
How to send a voice text on a kyocera duraxv and search contacts by typing first letter of persons name?
That is a very basic flip phone and not a 'smartphone'.
User Guide - Kyocera
https://www.kyoceramobile.com/duraxv/DuraXV_User_Guide_Verizon_en.pdf
User Guide. Page 2. TOC i. Table of Contents. Get Started ................................................................................................................................ 1. Your Phone at a Glance .
Kyocera DuraXV LTE Manual / User Guide - Phone Arena
https://www.phonearena.com/phones/Kyocera-DuraXV-LTE_id10714/manual This is the official Kyocera DuraXV LTE User Guide in English provided from the manufacturer. If you are looking for detailed technical specifications, please see ...
Kyocera DuraXV+ Support ' Verizon Wireless
https://www.verizonwireless.com/support/kyocera-duraxv-plus/ Learn how to use and troubleshoot your Kyocera DuraXV+. ... An interactive guide on how make phone calls using your Kyocera DuraXV Plus.
KYOCERA DURAXV USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Kyocera Manuals > Cell Phone > DuraXV View and Download Kyocera DuraXV user manual online. DuraXV Cell Phone pdf manual download. Also for: Duraxv+.
May 20, 2018 | Kyocera Cell Phones
Do you lose al images if you go to reset all,or can you retrieve images
You can use software to recover you data back. But do remember act fast over it and don't try writing something more over it otherwise the chances of getting your things back will decrease.
Recover Deleted Photos Pictures from Android Phone
Jun 06, 2017 | Cell Phones
HOW TO RETRIEVE LOST PICS. FROM CELL PHONE
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% saf
Sep 28, 2014 | LG VX8360 Cell Phone
How to delete notepad logs
Something is running on your computer and writing to those log files. You could try booting into safe mode (F8 on startup) and see if you can delete them. There are other things you can do to delete them but they will take a lot more time to explain and do. If they are that important to delete please reply and I'll get you the info you need.
Nov 29, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Message on screen says "can't unlock maps". What should I do?
    • If you see a "Can't Unlock Maps" message, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
2. To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it, connect the satnav to your computer and go to www.garmin.com. Select your country from the drop-down list and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
3. Retrieving your unlock codes:
  • Log into your myGarmin account
  • Select Manage Maps
  • Select Details
  • The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  • Plug your Garmin device into the USB port
  • Double-Click on My Computer or Computer located on the desktop
  • Right-Click on the Garmin or nuvi drive
  • Click Explore
  • Double-Click on the Garmin folder
  • Right-Click in a blank space in this window
  • Move your mouse over the word New
  • Select Text Document
  • Press Enter / Return on your keyboard
  • Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  • Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Change the Save As Type to All Files
  • Type gmapprom.unl in all lower-case letters for the File name
  • Select Save
  • Close the Notepad window
  • Delete the New Text Document file
  • Disconnect the Satnav from your computer
Creating an unlock code file for Mac:
  • Open the TextEdit application located in the Applications folder on the Mac HD
  • Click Format
  • Select Make Plain Text
  • Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  • Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  • Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
4. If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  • Click Explore
  • Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Type gmapprom1.unl in all lower-case letters for the File name
  • Select Save
5. Selecting maps on your Garmin Satnav:
  • Touch the wrench icon on the Where to/View map screen
  • Touch Settings (or Locale on some models)
  • Touch Map
  • Touch Map Info
  • Press the checkbox next to the maps to be selected on the satnav
    A tick will appear in the box. The map is now selected.
Oct 23, 2010 | Garmin nuvi 205W GPS Receiver
When I turn it on it says "Can t Unlock Maps? What does this mean?
The "Can't Unlock Maps" message appears because the unlock code is missing from your satnav. To solve this problem follow the instructions below:
Remove any microSD / SD cards in the device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
After unlocking the maps they may need to be enabled as described below.
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Sep 17, 2010 | Garmin GPS
I have a Garmin Nuvi 250, when I start the unit it displays "no detailed maps found that support routing". I have checked the drive and it has over 1.3 Gb used. I used the unit last weekend but it doesn't...
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have registered your satnav. If you haven't already done so connect your satnav to the computer. Go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your Garmin product. Follow the prompts. You'll have to create a username and password. Write them down and keep them safe as you'll need them again anytime you need to update your maps.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
I get the error no detailed maps found that support routing. Hwow Do I fix this?
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device in the botton paragraph
  1. Go to www.garmin.com and log into MyGarmin. If you don't have a MyGarmin account you'll need to register your satnav to get one. To register click on MyGarmin and then on Register your garmin product. Follow the prompts.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 06, 2010 | Garmin nuvi 260W GPS Receiver
I AM USING KYOCERA 8030 IT NETWORK CONNECTED EVERY TIME I PRINT IT PRINTS TWO BLANK COPIES WHY?
are you facing same problem with other document like notepad ...... please check it please ..... open a notepad type some thing like test print and give print and check its comes blank pages or not .... if its not coming please check the document setting how many pages your document heaving you can give number pages you want to print ....... if you facing same problem with notepad please post you comment ........... and try to uninstall the printer driver and reinstall it ..............
Dec 29, 2009 | Kyocera Office Equipment & Supplies
Cell Phones Logo
23 people viewed this question
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
