Question about Dometic Heating & Cooling
I wan't to control this unit ? To stay on till I turn it off?
    Top Expert:
  • Dometic Master
  • 7,361 Answers
Make sure fan on auto
Posted on Oct 06, 2017
How do i lite the pilot light to use in my home?on a confort glow naturel gas wall mount heater
perhaps you can find it through this website . Technical Support but you need to turn the unit topilot then push down on that control knob hitting igniter at the same time. then hold down till the thermocouple get hot enough to stay on then turn control know to whichever setting you want
Feb 18, 2015 | Heating & Cooling
How do i program a avol ma001 remote control
On the average remote you can have the remote find the code. Hold down search button till light blinks than select what you want to operate.hold that button down till it blinks and stays on. With device turned on keep hitting the off button till it turns off .As soon as it turns off hit the inter button.
Dec 19, 2014 | Televison & Video
Fan stays on
This sounds like the BCM and that is a computer that runs all the internal devices.
Dec 06, 2013 | Cars & Trucks
Have Big Brookstone remote, now have a Vizio tv, need to know how to reprogram remote to work with new tv
hold down code search till the light stays red then hit tv then press power repeatedly till it turns the tv on or off imediatley press enter once it does.
Sep 24, 2010 | Brookstone 538744 Remote Control
My 55,000 btu reddy heater it turns on and runs and pilot light turns on but it's like it doesn't ignite and turns off.
These heaters have a thermal control that requires the unit to get to a preset temperature, before the gas flow valve will stay in and let the heater run steadily.
When you are first starting the heater, it has to have the fan plugged in and you have to hold in the gas valve, and then hit the electronic spark ignitor until the unit lights.
Keep holding the gas valve in for a good 45-60 seconds (or longer) until it will stay in and remain on. Sometimes in really cold weather, these heaters will peroiodically shut off and will have to be relit.
The auto valve used on these gas heaters is designed to shut off the gas, should the flame go out or get blown out,or for any reason. It's a safety feature that can't be overridden nor would you wan to.
If the heater won't stay lit following the proper method, you'll have to remove and clean out the gas inlet/orifice, as it might have a partial obstruction in it. You may have replace the regulator if the orifice is fine, as that's about all there is with these types of heaters.
Hope you find this Very Helpful and best regards!
Sep 23, 2009 | Reddy Heater-30-55,000 BTU Variable
Can somebody tell me how to program a RCA 312w universal remote control to a emerson tv I have the intruction but I can not understand them thak you.
This will work with any devise and the rca remote.
1. turn on the device you want manually and hold the devise key, while holding the devise key press and hold the on off key till it stays lit.
3. point it at the devise and press PLAY for 5 sec. until it goes off. If it doesnt turn off after 5 secs. press and hold play again for 5 secs. repeat till unit turns off.
4. After unit turns off press and hold Reverse for 2 secs. until unit turns back on.
5. After it turns on hit STOP. and your done. Hope this helps.
Feb 25, 2009 | RCA Universal Remote Control
Heat stays on no matter what the therm temp is set on any ideas
If the stat has an installer set up did you configure it for your specific system type? (heat pump,fossle fule,and fan control
Jan 08, 2009 | Heating & Cooling
test the temperature sending unit.  most mazdas built after 1998 have 2 of sending unit is for the the guage in the dash, the other sending unit goes to the vehicle computer, which in turn controls the idle and fuel to air ratio for the vehicle. if it is getting a bad signal or none t all it thinks the car is still very cold and causes it to run ruff and the light stays on  till reset
Jul 22, 2008 | 2003 Mazda Protege
Omnitech jumbo universal remote control and vizio hdtv
Here are the instructions for auto code search from the Omnitech manual:
Automatic Search
There is another way to set up your controller, that does not use the brand code lists. You can let your
controller search through all of its available codes automatically in order to set the connection to the
target device. To do this, follow these steps:
1.Turn on the target device.
2.Point the controller at the target device and press and hold the Code Search button for around 3
seconds, until the LED light stays red.
3.Next select the type of device the target unit is by using the Cable/TV/VCR/DVD/Sat Buttons (i.e. if
it is a TV that you are trying to control, press the TV button). The LED light should then blink once,
then stay red.
4.Press the On/Off button on the controller slowly and repeatedly until the device you are trying to
connect with turns off. (Note: the LED light will blink each time you press the On/Off button). When
this happens, press the ENTER button in order to store the code and the LED light will turn off.
Jan 02, 2008 | Big Button TV Universal Remote
Heating & Cooling Logo
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
