I need to get reimbursed for the coins I won - Washing Machines
I just won a quest 18,000 coins & I didn't get the coins. I tried to make purchase & it said card didn't match. I used it Friday & it worked
This is so sad - but nothing to do with cameras. Anyway, so many coins would weigh a fair amount - you are probably far better off without them.
Aug 20, 2017 | Cameras
The FIFA 17 free packs
Try this website: https://goo.gl/ZdZATM. I usually buy FIFA coins and open packs. Some times I lose the coins through opening packs, but most of the time, i won the coins that made me satisfied. I think it is reliable absolutely.
May 19, 2017 | The Video Game Consoles & Games
I returned Levi woman's jeans (approx. Feb.) cannot find reimbursement on credit card. Lost paper work
If you paid with a card it should have been reimbursed to card, so you shouldn't need any papers?
Mar 12, 2015 | Levi's 501 Short
I am missing 10 crowns, 100k+ in coins and long build items.
Contact the publisher of the game. Explain what happened, and hope they reimburse you.
Feb 09, 2014 | Apple iPhone Cell Phones
Cash flow 500
This section is for computer problems. But, you could make sure the coin mechanism is for the correct currency and is working.
Apr 27, 2013 | Computers & Internet
Its a commercialcoin operated machine that won't start washing what could be the problem please?
open the coin dispenser and push in the start button that the coin lever should push in when you put the correct coins in the dispenser
Feb 04, 2013 | Maytag Washing Machines
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
My coins on diwips games ,,best casino have been taken,,no my coins are a minus 414,000,000 ,,and i cat play,,,why?
YAL HAVE NOT PAID ME..I HAV WON ON BIG WIN OVER 10,000,000..YAL DIDNT EVEN GIVE ME HALF.YAL STILL NOT PATING ME ON BIG WIN..I WROTE DOWN DAY TIME AMOUT. DIDNT GET A COIN.JUST THAT YAL HAV PAID ME.YAL DIDNT .I PAY TO BUY COINS.I USE TO LIVE YALS GAMES.BUT YAL ARE CHEATING PEOPLE OF THIER COINS FATZ 361 361 @YAHOO.COM
Sep 28, 2012 | Diwip Gaming Networking Best Casino
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
