Can I replace a T370XW02 VE CB t-con board with a T370XW02 VC 37T03-C00?
The t-con board on my LCD stopped working and I need to replace it. There is a 50$ difference in price and I want to know if I can get away with it.
  • 718 Answers
SOURCE: Is the T-Con board the LCD controller? What is
Website has Sony LCD Controller 400WSC4LV0.4 for the KDL-40S2000. Other sites may also have it.
Posted on Mar 06, 2009
  • 10594 Answers
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Posted on Mar 28, 2011
  • 11361 Answers
SOURCE: Sceptre x37SV-Naga inverter board part number is
4h.v1838.411 Picture
4h.v1838.241 Picture
The 2 boards are not exactly the same, the 241 does not have the small transformer installed by the first connector (as shown in the picture) and 241 is for AUOPTO LCD panel T370HW01 V.2.
The 411 has the small transformer on the board and it is made for AUOPTO LCD panel T370XW01.
It may mean that the pin-out of the connectors may not be the same. I would be real carefull about using the wrong board.
By the way, the fuses check out OK?
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Sep 01, 2011
SOURCE: Hannspree 28 Inch Lcd Tv Model Number HSG1075
Stop buying hot TVs folks. If you bought it legit, you can take it back.
Posted on Oct 23, 2013
  • 75017 Answers
SOURCE: How does a T-con Board works?
It is difficult to type in all here by this window, as it is too much. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 18, 2014
Why is my TV burning through T-Con boards? Ever time I replace one, it works for 2 hours and then I lose picture again. I've replaced 2 so far.
Hope the TV have problem with the either power board or the lcd panel. Try to check the power supply is its produce correct voltages mentioned on its connectors if you need help then check the video for that. if the power supply finds ok then you have problem with the lcd panel. In lcd panel there is a some ics which used as the driver of the pixels. the tcon sends data to these ics. and if any onf the ics draws more current from t con board then it can dame the t con. They are not replaceable one ,its integrated to the panel. if its faulty then you have to go for a new panel for that tv. And it would be a expensive repair.
Testing LCD TV Power Supply BoardsSTEP BY STEP
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
Nov 11, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
My TV has vertical lines
Probably the t con board is faulty. first you have to check is there is any bad contact in the connections on the t con board. Remove and reconnect all the connections on the con broad. if the problem exist even after that you have to go for a new t con board . in some tvs 32 the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Sep 25, 2015 | RCA Televison & Video
Vertical colored lines on entire screen, sound ok
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
TOSHIBA 32bv500b screen stops working sound works fine
I'm having a hard time finding any parts for the set besides the power supply board. The T-Con is usually located top center on the back of the LCD panel. It will be under a metal cover. Sometimes, the t-con circuitry is built onto the main board. If this is the case with yours, you will have to order the main board. Feel free to send me a pic of the back of your set.
Jan 06, 2013 | Toshiba Televison & Video
How to replace sansui lcd screen
The LCD screen replacement is a skilled work. Almost all screens comes attached with its driver board, known as 'T'Con' board. You must have through knowledge in electronics to do this work, as any connections to T'Con board have change, it might damage both T'Con board as well as new panel too.
Jul 02, 2012 | Sansui HDLCD-3212 32 in. LCD TV
SONY KDL-46W4100 LCD colour horizontal lines...
Your tv have problem with the T con board. The t con board drives the Pixels in the lcd screen . If there is some problem with the t con board then this can exibits such problem as you mentioned. Normally you can find the t con board in the bottom center of the lcd coverd with a metal cover. Its part number is SONY T-CON: E40951307. If its avilable then try to replace the same which will solve the problem. Its a regular complaint with the Lcd tv's. I have added the picture of tcon board.
Som times if there is any loose conatct in the pannel connection which comes to the t con board then also the same problem can occur. Before going to replace the board do one thing remove all the connections to the t con board and reconnect it. Some times it will solve the problem. If you need any more assistace feel free to conatct me through fixya.
Dec 12, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites, to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
We hope you have an answer and solution to our problem. Our Bravia is nearly three years old. Was working well until a few weeks ago. The screen gets divided into four horizontal segments from right to...
Hi Andrew,
The failure with your LCD is with a defective T-Con also called LCD controller board but is some cases it could also be a defective screen. The cheaper way for the time being would be to replace the T-Con board and hopefully that should fix it. If after replacing the T-Con board the LCD still fails then the screen is way to expensive to replace, the cost of a new screen would cost the same as buiyng another LCD or more.
Check this link to find the T-con board.
This board is located in the upper middle part of the LCD cover with a metal shield.
Let me know if you need further assistance.
Jul 30, 2010 | Sony BRAVIA KDL-46V3000 Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
