Question about Husqvarna Garden
My Husqvarna ride on LTH1797 always had a start problem sometimes starts if I wind the fly wheel compression, 3 new batteries haven't helped.
    Dedicated:
    Visited the website for 20 consecutive days.
  • Husqvarna Expert
  • 242 Answers
I would start with adjusting the exhaust valve . When the gap is to large the compression release can not work properly and will sound and feel like a low battery. When the valves are adjusted correctly the compression release will hold the exhaust valve open a little and allow the starter to spin it over with less resistance and once started the rpms will increase and centrifugal force will retract the lobe and compression will be full on. I am attaching a photo of what this part looks like on the camshaft not that you should need to go in there but just to satisfy your curiosity.
My Husqvarna ride on LTH1797 always had a start pr - 26393054-zt0kuptr5sa2rykdtnzowgsz-2-0.jpg
Posted on Dec 12, 2016
Does not Charge Battery
time to change charging system under fly wheel
did you have to jump this mower and use a car battery of high boost charger ? if so you burned out system
Nov 19, 2013 | Briggs & Stratton Garden
My 2000 flstc after I ride for a while the starter has trouble engaging and just zings ,I just put a new battery in it and it will start after being on a battery assist for a day .
Have you tried pulling the starter and putting it back on? sometimes gears in a starter dont want to line up correctly and that is where the zing comes in, could have bad teeth on the starter or fly wheel as well that are causing this to occur... I have had the same problem with a chevy truck, the zinging and sometimes hangin up, I tightened a bolt on the flywheel and rehung the starter,it fired right up. check the wire connections also either loose or from corrosion on the starter connections as well as the battery... hope this helps.
Nov 02, 2012 | Cars & Trucks
12 hp briggs and stratton starter
the battery may be to weak try jumping it with your car its the same voltage the starter needs to spin out fast to in gauge
Mar 29, 2012 | Husqvarna Garden
Ran over a steel stake that locked up the blades and killed the engine.
hello ben, Again,i said that the key way on the fly wheel may be out of time so engine will not start, you could check the deck safety switch may have knocked out or adjustment,hope this helps.
Feb 18, 2012 | Husqvarna Garden
Husqvarna yth 2348how to check and see if battery is charging and
there are one to two wires that come from under the fly wheel. thy are attached to our stator (charging sys) the flywheel has a magnet on it. know the wires my or my not go to a voltage regulator than a fuss and to ether the solenoid battery side, or to the battery. the easy way to check is on your battery with a meter. check battery fri st than start your engine to see if the amps come up should be around 12.9 to 14.6 volt. make sure your at full throttle. good luck, let me know.
Oct 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a Woods Zero Turn Mow n Machine powered
Try taking the cover off to get to the fly wheel and use some fine sandpaper or emery cloth to clean off the magnets on the fly wheel and the two little prongs that set really close to the fly wheel.
My white wouldn't start right away and I did the above and now it starts great.
Let me know if that helps.
Thanks
Roundo4
Jul 31, 2009 | Garden
Husqvarna will not start-was warmed up
u need to check the compression.u push it with your hand,is a bad sign.
Jun 01, 2009 | 2008 Husqvarna TC 450
Lawn mower will not hold charge with new battery sometimes starts sometimes no l 120 john dear mower I change my alternator, but it was not turn the fly wheel. what I did wrong
Often mowers come with batteries which simply do not have the cranking amps to do the job. Have someone look at your mower and see if your attery has the sufficient cranking amps.
May 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower will not start
Hi
Take the spark plug out and pour a little bit of oil in the cylinder and crank it over without the spark plug in. Make sure ground wire is clean on both ends.
Apr 13, 2009 | Garden
Garden Logo
35 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
