How to change aspect ratio of THT-6000HDMIA dvd player to 16:9. Mine doesn'nt allow me to hange the 4:3 ration output. The TV monitor is a 39" LED Telefunken set
When I go to SETUP menu on DVD, the 4:3 cannot be accessed or changed
    Habit-Forming:
    New Friend:
  • 34 Answers
Should be in the dvd player setup? Nothing to do with tv type.
Posted on Dec 10, 2016
Testimonial: "Peter, thank you very much. On going back to the initial SETUP menu for DVD player I was able to click 0n 16:9 aspect ratio. DVD player 100% now"
I'm trying to change aspect ratio from 16-9 to 4-3 on dxc-d30ws
get the onscreen menu up and alter aspect ratio settings
as the ratios are changed you will see the screen change to suit the new ration
it it is a late led type you may have to select the pixel sizes to get the screen size to change
Jan 13, 2017 | Televison & Video
How do you set cable to 16:9 output?
Different channels are broadcast in different aspect ratios, depending on the network and the show(s) being broadcast. Many older show are still broadcast in the 4:3 ratio to avoid distortion. Currently, there is nothing in the broadcast signal that tells the TV what aspect ratio to use. Therefore, TV remotes have a selection button (mine says "P.SIZE") that allows the user to change the aspect ratio to optimize the viewing experience.
Sep 05, 2014 | Hitachi Televison & Video
How to adjust aspect ratio on sony kdl-v40xbr1
Hello
To take advantage of the wide mode feature on your TV, Set the DVD players' aspect ratio to 16:9. For details, refer the operating instructions supplied with your DVD player. Aspect ratio must be set with DVD player. Not with the TV. OK.
Feb 05, 2012 | Sony BRAVIA KDL-V40XBR1 Television
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
People look short and fat
You are trying to display standard definition TV 4:3 ASPECT RATIO to fill up the 16:9 screen and that is what you will get. You need to use the 'APSECT', 'P.MODE', or 'WIDE' button to set correct aspect ration to match the video source aspect ratio. Please see you owner manual for more details.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 07, 2010 | Vizio Televison & Video
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
The RDR-VX535 does not transfer the 1:33 aspect ratio from VHS to
Did you try the unscaled option, that sould fix the issue.
Apr 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Picture is to tall. it cuts off the top of the heads
It sounds like you have the image on the perspective. If you tv is 4:3 aspect ration the video source (cable box, dvd ) must be set for a 4:3. If you have a 16:9 ratio (widescreen) the soutrce should be set to 16:9..................Nevermind, Just looked it up you this TV is 4:3.
Your TV remote will have a button to toggle/change the aspect ratios of the TV. Button could be called picture/aspect/image etc. If you have an HD cable box you need to go into the video setting and chnage the aspect ratio to match the 4:3 tv.
If you need more help, please respond with more deatils.
Jan 19, 2009 | Sanyo DS32830H 32" TV
Projector Image Problem
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Sep 21, 2007 | BenQ MP610 Multimedia Projector
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
