My Raynor garage door opener model cst411ss will not close all the way
It stops coming down when its about 2 feet from the floor
  • 1,057 Answers
Does it just stop or does it stop and go back up. If it just stops you need to adjust the down switch on the motor head. Before you do that make sure nothing is in the track blocking it from going all the way down. If it stops and returns to the top you will need to set the elec. safety eyes that go across the door. You can tell if it is the elec. eyes by holding the wall switch in and it will over ride the elec. eyes and the door will go all the way down. Hope this helps.
Posted on Dec 10, 2016
My garage door won't close makes Moab sounds. Needs a manual of raynors model pilot
Hello, Melvin -
If you have not yet thought to contact Raynor Garage Doors directly and ask for help, I suggest you do so. This is the link to the Raynor Garage Door Contact Us web page:
.http://www.raynor.com/contact.cfm
You will find the Consumer Inquires phone number there.
I have no idea what "Moab sounds" are.
Best wishes.
Apr 27, 2018 | Building Materials
My chamberlin chain drive garage door opener closes within 2 feet from the floor -- stops then opens [ the 2 eyes aren"t the same color ]
Try adjusting the lower limit on the garage door opener. It is a set screw (of some sort) on the back side of the opener. Once you make an adjustment, open and close the garage door once to see the effects. Keep repeating until you get it where you want. But you must cycle the door open and closed to see any change. If you are still having a problem, attempt to align your interference sensors and make sure nothing is blocking the light.
Nov 16, 2017 | Building Materials
Raynor garage door motor won't run and won't open the door. It is not sending power to the system despite being plugged in to a working outlet.
More than likely, the transformer in the opener is fried. You need to verify 110V power coming into the transformer, and that there is 24V AC power coning out of the transformer
Oct 03, 2014 | Raynor Garage Doors 4050047 Raynor PEC-R4...
Why is my garage door suddenly reversing when going down?
Deb, that reversal is a child safety device - if the bottom edge of the door detects contact with any object, it'll immediately reverse so it doesn't kill a child. Or a cat, dog, whatever.
The opener mechanism should have a stop switch that prevents the door from closing hard against the floor - that stop switch needs to be adjusted so that the door will stop JUST before hard contact. That'll take care of it "bouncing" off the floor & reversing. As to it reversing before it touches the floor... examine both guide rails closely to see if there's any obstruction that the door's bottom edge may be contacting to trigger the child protection reversal switch.
Aug 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster Garage door model 3280 and I changed the belt and when I try to open the door it only open about 2 feet from the floor.
Remove the belt and then run the opener until the sprocket on top of the motor runs in the counterclockwise direction and stops. Now with the door in the open position replace the belt. Some adjustments of the up and down limits will be necessary.
Sep 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage door opener is not cycling all the way closed, before returning fully opened. It is traveling about two feet down before stopping and gong back to the opened position. There is no obstruction in...
If the main lights are flashing 10 times it is a door sensor problem. If the lights are not flashing it is a bad RPM sensor board which is a small printed circuit board just in front of the motor. It can be purchased at Sears or any good door opener service company.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Raynor garage opener-remote only works close up sometimes
check to seee if the little wire that hangs out of the operator is hanging out. This wire is the ant. if this is not the problem replace the 12volt battery you can buy them anywhere. make sure you didn't cut off the ant. wire (I have seen customers cut thios wire thinking its an extra and not needed or place the wire inside the box very little signal that way have to be very close)
Jun 05, 2009 | Building Materials
Raynor navigator garage door opener won't work in bright sunshine
WOW I NEED TO RAISE MY RATES!!
I DON'T KNOW THE RAYNOR PRODUCT. HOWEVER, WITH MOST OTHER BRANDS THE PROBLEM YOU DESCRIBE CAN BE SOLVED BY SWAPING THE POSITION OF THE SENDING RECIEVING EYES THUS GETTING THE ONE THAT IS BEING AFFECTED IN THE SHADE
HOPE THIS HELPS
Apr 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster security + model 1265 NOT CLOSING PROPERLY
wbuero, I had same problem two weeks. The door springs weaken over time and may need to be tightened - check opening force manually. Manufacturer also recommended reviewing install guide to be sure opener arm is attached at proper angle. The opener on my professionally installed door was not connected properly. It that doesn't work, the opener drive train or door track/wheels may need maintenence.
Jul 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
