How to adjust tension on drive belt on Singer Model 1120 sewing machine.
Belt seems to be too tight. I can get the motor to run by giving it a little boost with my finger back cover is off machine. When running the machine runs slower than usual. Motor will not restart most times without the finger boost.
    Top Expert:
  • Washing Mach... Master
  • 49,142 Answers
Take it in for a service and a check on the motor operation
needing a help to start indicates a motor problem and not a belt tension problem
Posted on Dec 10, 2016
How can I tell what year or model a Singer is?
Hi Donna,here's a link to your Singer,just enter your serial number to find out what year model it is. Singer Sewing Machine Company Serial Numbers
Sep 29, 2016 | Singer Sewing Machines
Thread gets caught in the screw behind the thread take-up lever
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
Sep 25, 2008 | Sewing Machines
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
My singer 1120 sewing machine needle will not move. When I press the foot pedal the motor makes a sound but the machine will not sew. The machine will sew if I crank the hand wheel but it is very...
I presume that you have checked that the clutch to wind bobbins is reengaged?? It is easy to forget sometimes. If your machine has a knob inside the flywheel to do this, then just check that it is fully tighted back up to reenage the motor drive.
Otherwise it may just be the drive belt has worn/broke/is slipping internally. I wouldn't dump it just yet, it may well be repairable.
The motor belt is available here http://www.sewingpartsonline.com/motor-belt-singer-007156xxl5.aspx so if parts are on the market then it may well be worth taking it to a repair shop and getting a quote to fix it. Depends on how long you've had the machine and what you paid for it and the cost to repair vs buying a new one.
If you or someone you know is technical, they may want to have a go at opening up the case and seeing what is happening around the drive/flywheel area - just make sure everything is disconnected from the power first.
Sep 07, 2011 | Singer 1120 Mechanical Sewing Machine
Belt came off
well that is very nice idea you can fix with your self provide talls most commonly use.Set of screw driver,open and socket wrench,pliers etc...Remove the top cover plate by loosening bolt holding the cover and cover besides the handwheel where the motor was installed besure it was unplug from ac source(No power)Check the motor holder that attaching from casing.You can see the motor coupled by the belt.In the motor holder there is a bolt slot adjustment for tensioning belt tighning and loosening.If you want to disconnect the belt and replaced loosen the tension and pull out the belt.Sometime belt are sliping to the pulley it affect
the sewing machine operation,you can tighten from adjusting the tension of the belt.adjust not so tight after adjusting try to run manually first by turning handwheel freely if the motor will run freely with out obtruction no power supply.If your satiesfied try to run with power supply but jag twice first to be sure no problem occured before continous operation.
Mar 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Washing Machines Logo
Top Washing Machines Experts
